Van Sickle, Tallmans, TISCO Paint |
dfwallis
Topic: Van Sickle, Tallmans, TISCO PaintPosted: 28 May 2025 at 9:06pm |
I gather from my latest quest to buy paint that Van Sickle has been making both Tallmans and TISCO (Persian Orange #1) paints for awhile and that both Tallmans and TISCO brands are being phased out in favor of the Van Sickle brand. It seems to be implied that this has been the same paint formulation for all 3 brands for some time, despite the marketing claims that one is much better than others. I looked at the PPG version (60080, which may be the true original) but all of the "color samples" online don't look anything like the original PO #1 on the tractor. It's much too red. I can only guess that the online representations are inaccurate. Van Sickle does seem to recommend using clear coat which I did not do because the tallmans source I used made no reference to it.
1952 CA13092
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4065 |
Posted: 29 May 2025 at 9:46am |
who does the iron guard that the impliment companys sell
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4871 |
Posted: 29 May 2025 at 10:19am |
I know nothing about paint. But I know 2 people that have painted crawler tractors with Tisco Persian Orange paint. They were not happy in that it faded very fast. Not show tractors so they did not sit in the barn, but outside like 80% of working tractor out here.
dfwallis
Would appear to be Krylon.
1952 CA13092
dfwallis
Posted: 29 May 2025 at 10:28am |
It's oil based enamel and isn't very durable unless you add the hardener and they recommend a clear coat on top. I initially failed to add the hardener, but also had a lot of trouble with humidity in the compressor lines (took a 5 stage dryer/filter setup to resolve). I think it's probably good enough for most, especially if applied as recommended. I'd truly like to know what is the BEST paint and approach, though in case I ever do it again. I know that when I painted a 68 Olds Cutlass, Mustang and Beetle in the 70s, that I used Dulux enamel, hardener, dryer...But I also did not clear coat and it was not as shiny as I had hoped.
1952 CA13092
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 921 |
Thanks(1)
Posted: 29 May 2025 at 10:55am |
We've used Van Sickle for years. We have the best luck spraying 2 coats without hardener and the final top coat with hardener. We've never clear coated. some of our paint jobs are twenty years old & still look good.
HudCo
Posted: 29 May 2025 at 10:20pm |
nothing uglyer than clearcoat that starts pealing and it will at least faded paint can be waxed
Joined: 11 Sep 2009 Location: illinois Points: 90653 |
Posted: 29 May 2025 at 10:45pm |
Most paints you buy at the Hardware or BIG BOX stores are Alkyd Enamel.. Commonly know as tractor paint... It is what you use around the house to paint machinery, swingset, etc... Normally not the same quality as AUTOMOTIVE PAINT which is ACRYLIC ... im not sure there is a big difference in who manufactured the Alkyd Paint..
Decorative Performance of Acrylic Paint and Alkyd Paintalkyd paint and acrylic paint are often used as topcoats. The decorative performance of the two is not the same. Due to its slow drying speed, alkyd paint film is difficult to meet higher requirements, and it is prone to losing gloss and fading after long-term use. Acrylic paint dries quickly, and the film is hard and durable. Even after long-term use, it can still provide excellent gloss and color retention, making it better for decorative use. Characteristics of Acrylic Paint and Alkyd PaintThere is a big difference between the characteristics of alkyd paint and acrylic paint, particularly in terms of weather resistance and resistance to chemical corrosion. Due to the stable and hard texture, strong adhesion, and fewer micropores of acrylic paint film, it has a better ability to retain gloss and color, and is more weather resistant. alkyd paint is prone to serious loss of gloss and color, as well as peeling and powdering, after prolonged use, resulting in poor weather resistance. Edited by steve(ill) - 29 May 2025 at 10:49pm |
Posted: 29 May 2025 at 10:53pm |
You can buy Hardeners and add to the Alkyd Enamels to make them dry faster and harder... I have done that.... Not sure it will fix the Weathering if machines are left outside... I have not had good luck with keeping it " Gloss" when painting trailers that set out in the sun.... Keep a tractor INSIDE and it helps.
Codger
Posted: 30 May 2025 at 3:12am |
Sherwin-Williams introduced acrylics into the automotive finishes market in 1966. It has been the mainstay of the automotive paint and refinish market since. Alkyds had their place, and was the best current technology available till that time. The cost is reflective of the technology incorporated to state it mildly.
I've sprayed Van Sykle,Valspar, Rust-Oleum, etc. with about the same results and in a controlled atmosphere, it can be made to "stand tall" like other paints of better quality. It does have an open window much longer than acrylic based enamel paints, but both airflow and heat are friends here. I have never used a hardener in an alkyd paint myself. I tend to force dry anything by turning the heat up in the paint room to 140 degrees and let it go about 45 minutes and slowly cool down. Most don't have that option I know, but I do and use it. For panel work I have a short wave infrared paint drying lamp that will do about 1/2 the side of a car as example in just about 20 minutes at 140 degrees till you can color sand and buff once cooled down. Both methods work on either acrylic, or alkyd based topcoats.
That's All Folks!
HudCo
Posted: 30 May 2025 at 10:27pm |
put the lead back in the paint you would have somthing. i dont eat paint chips so i am safe
Robert2
Joined: 23 Dec 2024 Location: Catlin, Illinoi Points: 6 |
Thanks(1)
Posted: 15 Jul 2025 at 5:24pm |
Also you can’t tell true color from a screen
dfwallis
Posted: 15 Jul 2025 at 5:47pm |
Very true, but some of those online color chip samples are not even in the same universe.
1952 CA13092
