Valve lash? |
Post Reply |
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3203 |
Posted: 09 Feb 2020 at 9:20am |
Have a new to me 7040 and pulled the valve cover to replace a leaking gasket and want adjust lash as well. Service manual for 7020 & 7045 call for .018" cold. Would I be correct to assume this is the same for the 7040? Also discovered a leaking plug on the water jacket with a buggered up hex fitting. Hope this is an easy fix.
Orange Level Access Joined: 12 Sep 2009 Points: 19677 |
.017" or .018" COLD is just fine. Be sure to check both rocker arm shaft oil lines to be sure they are tight. Braze/weld a clip inside the cover front and rear to keep the gasket in place. Glue gasket to a clean and dry valve cover and let cure. Use 3M8001 yellow glue or something similar. Wipe a thin coat of RTV on the gasket with your finger just before setting it down on the head. Use RTV on the valve cover bolts to help keep from vibrating loose and still be able to snug them up later on.
plummerscarin
Thanks for the reply. Just getting to it now. Looks like you beat me to the tab
Yup. That could be one I did 30 yrs ago.
Edited by DrAllis - 16 Feb 2020 at 11:32am |
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3252 |
At least he was using his fingers and not a smart phone...……….
Post Reply | |
