Valve lapping |
3rd generation
Topic: Valve lappingPosted: 20 Nov 2025 at 8:25pm |
I’m sure this has been long discussed if lapping is needed. I just had hardened seats installed and valves ground. Personally I trust modern machining for a good seal. How many of you still lapped valves with hardened seats?
Joined: 11 Sep 2009 Location: illinois Points: 88807 |
Posted: 20 Nov 2025 at 9:24pm |
always a good idea to get a finish lap.. if nothing else, to CONFIRM it is correct..
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8696 |
Posted: 20 Nov 2025 at 10:22pm |
Can't hurt? When seats and valves are ground/cut correctly it's not needed.
Posted: 20 Nov 2025 at 11:35pm |
HELL NO !! Ask yourself this: do you think GM or FORD for example take the time to "lap" valves and seats after their modern and expensive valve grinding equipment has just mass produced hundreds of cylinder heads a day ?????? NOPE.
3rd generation
Posted: Yesterday at 4:52am |
Bluing would confirm a fit. I do think it’s a method appropriate many years ago and has stuck in the minds of some. My search has yet to convince me it’s needed. The hardened seats will do more for longevity than any lapping could provide.
Les Kerf
Posted: 23 hours 17 minutes ago at 7:20am |
When Grandson and I used my 100 year old Van Norman valve grinder and my Chinese-made seat cutters from Amazon to do a valve job on Mr Cato's Model C Allis-Chalmers head with the sloppy valve guides and cast seats, why yes, we most certainly felt it appropriate to hand lap the valves.
![]() Edited by Les Kerf - 23 hours 15 minutes ago at 7:22am |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3587 |
Posted: 18 hours 35 minutes ago at 12:02pm |
You could easily have it vacuum tested to expose any possible valve/seat fit leaks.
Posted: 18 hours 7 minutes ago at 12:30pm |
lapping it for 30 seconds would give you an idea of the seat and verify that all is well.. Just a quick test.
Les Kerf
Posted: 16 hours 1 minutes ago at 2:36pm |
Lapping valves after having been done correctly on modern equipment does no good and may reduce longevity by a small amount. I do not own such modern equipment ![]() It would be difficult to prove the difference on a vintage Allis-Chalmers tractor.
Sids
Joined: 16 Feb 2025 Location: belleville, ks Points: 9 |
Posted: 12 hours 3 minutes ago at 6:34pm |
I have always lapped valves. Why not? You can see the width and placement on the valve face and it shows on the seat as well. Just me I guess. Never had any problem. Now i wonder how many hundreds of valves and seats I have ground.
