Valve lapping |
3rd generation
Topic: Valve lappingPosted: 17 hours 26 minutes ago at 8:25pm |
I’m sure this has been long discussed if lapping is needed. I just had hardened seats installed and valves ground. Personally I trust modern machining for a good seal. How many of you still lapped valves with hardened seats?
Joined: 11 Sep 2009 Location: illinois Points: 88803 |
Posted: 16 hours 27 minutes ago at 9:24pm |
always a good idea to get a finish lap.. if nothing else, to CONFIRM it is correct..
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8694 |
Posted: 15 hours 29 minutes ago at 10:22pm |
Can't hurt? When seats and valves are ground/cut correctly it's not needed.
Posted: 14 hours 16 minutes ago at 11:35pm |
HELL NO !! Ask yourself this: do you think GM or FORD for example take the time to "lap" valves and seats after their modern and expensive valve grinding equipment has just mass produced hundreds of cylinder heads a day ?????? NOPE.
3rd generation
Posted: 8 hours 59 minutes ago at 4:52am |
Bluing would confirm a fit. I do think it’s a method appropriate many years ago and has stuck in the minds of some. My search has yet to convince me it’s needed. The hardened seats will do more for longevity than any lapping could provide.
Les Kerf
Posted: 6 hours 31 minutes ago at 7:20am |
When Grandson and I used my 100 year old Van Norman valve grinder and my Chinese-made seat cutters from Amazon to do a valve job on Mr Cato's Model C Allis-Chalmers head with the sloppy valve guides and cast seats, why yes, we most certainly felt it appropriate to hand lap the valves.
![]() Edited by Les Kerf - 6 hours 29 minutes ago at 7:22am |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3587 |
Posted: 1 hour 49 minutes ago at 12:02pm |
You could easily have it vacuum tested to expose any possible valve/seat fit leaks.
Posted: 1 hour 21 minutes ago at 12:30pm |
lapping it for 30 seconds would give you an idea of the seat and verify that all is well.. Just a quick test.
