Valve Clearance |
| Author | ||
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5362 |
Topic: Valve ClearancePosted: 11 Jan 2026 at 1:03pm |
Working on my D14, replacing the valve cover and manifold gaskets. I am going to check the valve clearances and make any adjustments if necessary while I have the valve cover off. Since many components have been removed to prep for paint I can’t start the engine to get it to operational temperature as the manual recommends. Question is, is there a big difference checking them cold versus hot? .012” is what the book calls for. Obviously much easier to check them at this point with all the sheetmetal off, or should I wait until I put it back together to get it up to operational temperature?
| Sponsored Links | ||
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5178 |
Posted: 11 Jan 2026 at 2:05pm |
I always set them cold, and add about .002" to the hot spec. I've never felt I could go through them all quick enough hot to be the same temp from start to finish.
AC720Man
Posted: 11 Jan 2026 at 2:36pm |
I agree with you ED, it wouldn’t be consistent on a hot engine by the time you went through them all. So you would set them at .014”? The book gives a range of .012”-.014”.
Thanks |
injpumpEd
Posted: 11 Jan 2026 at 2:40pm |
Probably so. Intake lash usually tightens up over time, exh usually gets loose.
Les Kerf
Posted: 11 Jan 2026 at 3:04pm |
I would set them cold at 0.014" and forget about it. Back in the day I set the valves on my 1955 Ford with the Y-block 272 hot and running. What a mess! Son-in-law has a 53 F-350 with a 292 and I just adjusted them to zero clearance cold and then opened them up 1/4 turn. It works out the same
![]() Edited by Les Kerf - 11 Jan 2026 at 3:07pm |
AC720Man
Posted: 11 Jan 2026 at 4:39pm |
The oily mess was my other concern Les. I’ve adjusted cold on my D17D and other tractors I have but just wanted to get some other opinions. I don’t recall adding any though which I understand why it’s suggested. Thanks to both of you.
Edited by AC720Man - 11 Jan 2026 at 4:42pm |
Clayfoot
Joined: 23 Sep 2024 Location: Southern Ohio Points: 47 |
Posted: 11 Jan 2026 at 5:56pm |
Has anyone done a running lash adjustment on these, or do you get too much oil spray?
Edited by Clayfoot - 11 Jan 2026 at 5:56pm |
Jim.ME
Posted: 11 Jan 2026 at 8:15pm |
With a .012 to.014 range l would go .002 over mid-range (.013) and set them at .015 cold.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3154 |
Posted: 11 Jan 2026 at 9:00pm |
For some reason seems like valves get adjusted to tight on old tractors,with low RPM motors like in old tractors I've found a little loose is better than a little tight.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5116 |
Posted: 12 Jan 2026 at 6:03am |
DrAllis suggested .015 cold several years ago. Since then, I have always used this setting. No problems, so far.
Posted: 12 Jan 2026 at 6:25am |
.015" COLD for intakes and exhausts on all West Allis built 4 cylinder engines. While some want to re-invent the method, this has worked for 50 years for me and is EASY to remember and do.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4216 |
Posted: 12 Jan 2026 at 6:58am |
I've seen it done on V-8's with hydraulic lifters. I can not imagine trying to do it on a mechanical lifter cam. I hate 'hot' valve lash specs. Like Ed said, who's fast enough to get them all set before the engine is cool? I recently set lash on my Farmall 450, they have a hot spec. So I added .002" and set them cold. Will check them after first run at head re-torquing time. Also put the head on the 756 gas yesterday, another hot spec. Will do same procedure as the 450.
IBWD MIke
Posted: 12 Jan 2026 at 9:56am |
I had a learning experience this morning I thought I would relate;
Reading the manual for the 756 where it talks about valve lash it has a footnote. It says, "engine warm means any temperature above 32 degrees F.". Well, that's a bit different than my thinking of warm! Guess I'll have another look at the 450 manual and see if it's the same. May be tightening them up a couple thousandth's. I have no idea if Allis, or any of the other manufacturers for that matter, used this description.
Les Kerf
Posted: 12 Jan 2026 at 11:35am |
My late Father-in-law had a handful of old beat up feeler guages from his years as a service station mechanic back in 1950's-60's. As I mentioned above, I have done it on old Fords in my youth but have since been enlightened
![]() Edited by Les Kerf - 12 Jan 2026 at 11:37am |
injpumpEd
Posted: 12 Jan 2026 at 2:31pm |
When I see the valve lash specs, they usually say cold, as in ambient temp, or hot as in engine up to operating temp. I have never seen one give a spec for actual cold temps.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1551 |
Posted: 12 Jan 2026 at 4:14pm |
I have always done valve sets at ambient temperature. Add .002 to the spec as all others have said!
AC720Man
Posted: 12 Jan 2026 at 10:19pm |
I set them at .014” today thinking the thread was done, checked at 8 am. Only 3 valves needed a slight adjustment.
Edited by AC720Man - 12 Jan 2026 at 10:20pm |
Ed (Ont)
Posted: 17 hours 24 minutes ago at 7:44am |
Should be good.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8789 |
Posted: 2 hours 18 minutes ago at 10:50pm |
Cat book says cold. .015 IN, .030 EX ....and give you plus or minus .003 on either side. Yes, .006 variance saying if in that range it's ok.
Edited by SteveM C/IL - 2 hours 17 minutes ago at 10:51pm |
