Valve clearance
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: Valve clearance
    Posted: 11 Jan 2026 at 12:15pm
Working on my D14, replacing gaskets on the valve cover and manifold. I was going to check valve clearances and make adjustments if necessary while I have the valve cover off. Since many components have been removed to prep for paint I can’t start the engine to warm it up to operating temperature to check the valve clearance as the manual recommends. Question is, is there a big difference checking them cold versus hot? .012” is what the book calls for. Obviously much easier to check at this point with all sheetmetal removed or should I wait until I put her back together and get it up to operational temperature?
I’m sorry I put this in the wrong place, I put it over in the farm section.
Edited by AC720Man - 11 Jan 2026 at 1:05pm
