Value of an A-C Electric Motor?
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Topic: Value of an A-C Electric Motor?
    Posted: 07 Mar 2018 at 6:10pm
My local grain elevator just removed it from their feed grinding equipment, It's 25HP, 440V 3-phase. It is burned out. The supplier would not take it for a core and told the Managers to just scrap it. Is there any collector following for these? What is one worth just for looks? Just found it so i didn't have time to call the scrap yard for a quote. Any ideas?
Thanks.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 6:12pm
Really doubt it,,, I was working at AT T in St Louis a few months ago and they have a few AC electric motors running various stuff, they were installed in the 30,s , pretty neat
Edited by DougG - 07 Mar 2018 at 6:14pm
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 7:15pm
Scrap motors are paying pretty good right now, other than that, used and especially  burned up three phase motors aren't in high demand.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 8:04pm
A motor rewinding shop could probably get it back in operation for a reasonable price (considering replacement)... as long as the 'burned out' is in the stator (not the rotor).  A set of bearings with shields, a good cleaning, and it'd go another hundred years.
I salvaged an AC 7.5hp 1800rpm motor from an old air compressor, it had some wiped-out bearings and boogered up shaft... a little cleanup with a file and some emory cloth, blew out the crud, put in new bearings, and mounted a toothed-belt on it, now it's in the belly of my Monarch 10EE lathe, driven by an Allen-Bradley 1336F varible frequency drive at up to 180hz, it'll really cut metal...
