Valspar paint
Dave Wisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Topic: Valspar paint
    Posted: 11 Apr 2017 at 11:49am
Has anyone used this paint as to what to thin it to, or problems with it. Thanks DAVE
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 1:08pm
You need to get the mixing sheet for that paint. It will tell you with what and how to mix it. Paint store provided the sheet when I purchased the paint. It might be available from their web site.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 1:50pm
I have a tractor painted with it. Turned out nice
Can't fix stupid
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 6:57pm
I've painted a couple tractors with it and they turned out nice.i mixed it like it said on the side of the can. If you get a gallon of paint a gallon of thinner and a Pint of hardener you should be good. Whatever it said on the Sid of the paint can worked I just poured it in my $20 harbor freight HVLP. And sprayed it on turned out great and has held up well. The only place the paint didn't stay is on the step and top of the rear axle. That's where I keep throwing the chains when I'm done with them.
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2017 at 10:41pm
Have been trying the Valspar in the spray cans.  Seems to be  good color.  Thanks for the thoughts.  I am planning to use that eventially.
