Vacuum booster |
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1569 |
Topic: Vacuum boosterPosted: 29 Mar 2026 at 5:22pm |
I'm at my wits end with this customers 1999 chevy silverado pickup. Comes in with a broken brake line. Of course gm had to put the abs module under the can so you have a bundle of lines running along the frame rail and that's where it's leaking. Put in new lines and bled it. Took it for a drive and the pedal was hard with little braking effort.
Bring it back in. All the calipers move nicely and I cleaned up the pads so they float. Took it out again same story. Doing some investigation I find that I have next to no fluid coming from the abs to one of the front wheels. Seen this before abs fails. Got a junk yard abs and now I have good fluid flow to all wheels using my pressure bleeder. Drive it again and same thing. I've run out of things to check except for the master and the vacuum booster. Pull the vacuum line and the booster woosh's. So I know it holds air. Start pickup with line off and you have good vacuum. My question is can I have a booster that's junk but yet still holds vacuum? What are your guys thoughts |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35671 |
Posted: 29 Mar 2026 at 5:25pm |
You have a Bad booster chamber. Is not applying the stored vacuum. Inner works are screwed.
bobkyllo
Posted: 29 Mar 2026 at 5:49pm |
I was leaning to the booster but I was unsure if you could have a bad booster but yet have no leak or poor driveability.
All the bad boosters I've ever come across would not hold vacuum. Thank you for the reassurance. |
DMiller
Posted: 29 Mar 2026 at 6:23pm |
Can fail either way.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1592 |
Posted: 29 Mar 2026 at 7:12pm |
I find on a lot of this newer stuff you have to hook up computer and activate brakes with it. I had a 99 GMC2500. Did all the brake lines at once due to rust issues - plow truck. Could not get a pedal at all even after lots of manual bleeding. Finally hooked up computer, activated ABS a couple times. Quick manual bleed and 100% brake operation!!!!
Drove it for a few years after that with no issues and great brakes. Finally sold the truck and it is still working today. New owner turned it into a tire service truck and loves it! Edited by Ed (Ont) - 29 Mar 2026 at 7:16pm |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6124 |
Thanks(1)
Posted: 31 Mar 2026 at 1:47am |
I don't like to hear it, but I"m not surprised you're experincing this situation, Bob- I had a '99 Silv that darned near killed me when one brake line broke, and the ABS system prompty emptied ALL the brake fluid out onto the ground. I had a trailer in tow, with about 2600lbs of lumber stacked on it... I was going 35mph, on flat land, approaching an intersection where crossing traffic did not stop... and there was a 5-axle dumptruck coming from my left, and TWO loaded semis coming from my right. I must've been a little nervous, because I broke the E-brake cable right off when I stepped on it. Fortunately, quick thinking I grabbed the trailer electric independant, and locked them up... all the crossing drivers saw the smoke as I was rolling and realized what'd happened... they couldn't stop, but they moved far enough to keep me alive... I finally got stopped about 3ft into the intersection, but AFTER they'd moved far enough to squeak by me. GM really failed here- the ABS control system scheme should NOT have allowed that, and they should NOT have used such lousy materials in the brake lines. They used same steel tubing in fuel lines and vent line, too, all terrible with respect to corrosion resistance. That situation meant that NO shop would do anything less than a complete and full replacement of EVERY brake component. After finding that the ABS pump and plumbing was wedged in where it was, I cut the engine and transmission out (the 4L60E was of the 'problem' series that required a $4200 rebuild after ring gear broke 8 months before). They're lemons, so I made lemonade. I removed and sold the engine, trans, and T-case, cut the frame, cab, and body into pieces, and took it to the recycling yard, to make certain it would NEVER hurt ANYONE after that.
bobkyllo
Posted: 20 hours 40 minutes ago at 9:07am |
An update for you guys.
The customer was not in a hurry so he said I had time to fit it in between other jobs. Yesterday I put the booster in line we all pretty well agreed on being bad. Unfortunately that did not fix it. Up until yesterday I had been working by my own. I got dad involved yesterday and we decided to start from scratch. Talk about what has been done and what could be bad to give me this trouble. Dad said let's jack it up and make sure all the brakes actually stop. To my surprise the front tires did not stop. Up until yesterday I had fluid to all wheels using my pressure bleeder. Dad said let's bleed the front tires with the pump 3 times and hold it method instead of using the pressure bleeder. Again to my shock I have no fluid going to the front wheels. I moved all the way to the master cylinder and I found the one pretty was not working. I installed a new master cylinder even though the one in there looked brand new hence the reason I over looked it and they work beautifully. Anyone care to guess why I could get fluid with the pressure bleeder pumped up to 15 psi but if I had a helper pump the pedal and bleed the brakes I don't get fluid. I'm very puzzled. Thank you for the help guys. Now to figure out how to charge the customer for this. Edited by bobkyllo - 20 hours 37 minutes ago at 9:10am |
Ed (Ont)
Posted: 19 hours 42 minutes ago at 10:05am |
Have you tried hooking up computer to activate abs. That's all it took on mine and symptoms sound the same. Have had several professional mechanics tell me the same thing. I realize not everyone has a professional scanner but you may have to ask someone to borrow one. Maybe NAPA or some parts store will rent one to you. Right now you are throwing parts at it and wasting a bunch of money! The truck drove until the line broke so all those parts were not faulty!!!! Possibly one was but not all of them. Hope you get it sorted out.
![]() Edited by Ed (Ont) - 19 hours 35 minutes ago at 10:12am |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Posted: 14 hours 34 minutes ago at 3:13pm |
Not automotive related, but I learned whenever I was called in to help on a problem child (medical equipment) and I saw, or was informed of the presence of "new" parts I was very skeptical of that part(s)! Seen it many times where a tech replaced a part that either didn't solve the problem, made it worse, OR created a new problem.
I am still confident of this;
