V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: V8
    Posted: 20 May 2018 at 11:04pm
Hey was watching tractor pulls on RFD today. There's was a newer Massey with a v8 in it, was wondering what the base engine is, did Massey have v8 in that style tractor. Just curious, thanks
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 11:21pm
that massey was a V8' there was a lot of masseys with the V8 the manifold gets red hot.was it the 10000 pro' stock?
Edited by dawntreader74 - 20 May 2018 at 11:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2018 at 11:29pm
I don't remember what class, sorry. Yes it got red hot.
IV seen the older one with them. But cool
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 7:17am
Yes Massey used a  V8 made by Perkins  in several models.  We have a good one locally. check out Carton Cope Warpath.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 8:52am
When I grow up, I wanna be like Carlton Cope  !!!!!
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 11:25am
Prostock class from Hillsboro Wisconsin
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2018 at 12:38pm
Perkins 640 V8 in those pro-stocks! Very impressive to watch run! The 1150 came out with a 510 V8, then went to 540 for the 1155 and the 2745/2775 I think. The 640 was used in the 2800/2805 some 860 combines and the White 9200/9720 combines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2018 at 12:02am
Neighbors had Masseys .Last upgrade was a 2805.Was a horse when it wasn't in the shop! Engine got in their pocket one too many times.Down the road it went! Still has a couple 1100 series but everything else is Green.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 7:26pm
Not a V engine but a story on one of the first high HP tractors using GM Diesel
https://www.hemmings.com/magazine/hmn/2008/07/Oliver-Super-99-Diesel/1659600.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 7:33pm
seems another GM diesel was used also
https://www.dieselworldmag.com/features/2936-2/
7040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7040 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2018 at 9:20pm
Mike Everson from Belleville WI.built a newer body style Massey with the 640 v8. Called sleepnir (Norwegian mythical 8 legged horse) it pulled fot the first time in 2017. He is a huge massey fan and spent 3 years building it if this is the same tractor he went through 6 header designs before he got one to hold up where the four pipes come together that piece started out as a 70 lbs chunk of stainless and he machined that himself he does own a machine shop though.
Edited by 7040 - 09 Jun 2018 at 9:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 12:11am
did the 2255 oliver used the 3208' V8 CAT motor. they pull good also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2018 at 7:47am
The early 2255 used the Cat 3150 573 CID engine. Later in production, they went to the 3208 which is 636 CID. The 3208 is an update/improvement of the earlier 1150/3150, 1160/3160. the 11 being truck engines, 31 being industrial engines, the 50 being 573, 60 were 636. confused yet? lol! I would imagine Oliver/White switched to the 3208 because the 3150 was likely discontinued when the 3208 came out.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2018 at 9:12am
i have been going to to ask who uses cat perkins or other engines be sides the red and green ones
This page was generated in 0.270 seconds.
