Update on CA with knock |
Page <12 |
StewartMD
Joined: 10 Dec 2009 Location: Emmitsburg, MD Points: 314 |
Posted: 20 Jan 2012 at 9:41am |
Greg, Thanks for the insight. I really hope that I don't need to do all that you have done. I feel that this tractor didn't have that hard of a life but I could be wrong and it is around 60 years old.
Steve, thanks for the updates. Keep us informed as to what is going on with it.
I hope to work on mine this weekend. I didn't have any time this week.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 20 Jan 2012 at 11:15am |
Stewart
I would suspect your knock is a loose bearing or a worn thrust lip on the front main (I have yet to run into a loose wrist pin causing a knock). Most of the engines I have rebuilt were fixed with a rebuild kit and machine shop work, not too often did they require the replacement parts that this last one did. Just trying to help you focus on 1st determining the condition of your engine by inspecting every thing THEN deciding on what you want to do to fix it up. These engines will run fairly well on marginal parts so it is not always necessary to do a complete rebuild if all you are interested in is a decent running tractor. My pocketbook is such that when I go into the engine, I can usually afford to bring it back to "like new" condition. Not all are blessed with the available funds to do this, and I understand. I have also partially rebuilt a sick engine because I did not have the funds to do a complete "like new" rebuild. If you have the gages (and the skill to use them correctly) and determine that the pistons/cylinders are good...new rings may be in order; likewise with new bearings on an existing crank or just one new sleeve/piston. Just be confident that your assessment is accurate so you don't waste your time and money and have to go back into the engine.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
StewartMD
Posted: 20 Jan 2012 at 11:33am |
Greg,
I appreciated your feedback and insight. Obviously you are well versed with these engines. I should be ok doing measurements and checking things. I will report back with my findings and hopefully you can comment as to where I should head. I am lacking funds at the moment otherwise I would do a full overhaul, but then again with the little use this tractor sees, it is hard to justify. I wonder if I have more than one problem because I know for sure that the connecting rod is loose at the wrist pin. There is alot of slop in it that I can feel by just reaching up from the underside and jerking it back and forth.
scott
Joined: 12 Sep 2009 Location: michigan Points: 2769 |
Posted: 20 Jan 2012 at 11:43am |
No chance the cinch bolt came loose at the piston pin?
StewartMD
Posted: 20 Jan 2012 at 1:08pm |
Scott,
I guess that's a possiblity. I'm not familiar with what that is. I need to study the service manual a little better.
JeffMOnt
Joined: 11 Sep 2009 Location: Ottawa, Ont Points: 129 |
Posted: 20 Jan 2012 at 1:28pm |
Cinch bolt is the bolt that clamps the rod to the wrist pin.
StewartMD
Posted: 20 Jan 2012 at 2:43pm |
Thanks Jeff. I didn't know that was what it was called. I will look for that.
Page <12 |
