Unstyled WC question
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: Unstyled WC question
    Posted: 30 May 2010 at 7:43am
Did Allis ever offer the unstyled WC with electric start? A friend of mine just bought one and thinks it is factory electric start. I have yet to see it but he says it is beautiful. Paid 300.00 bucks for it. He makes me sick! Lol... He is a deere guy and said that this is one of the best looking tractors he has. I may be able to convert him...
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 8:12am
No, but it seems to have been a popular conversion.  There's probably a casting date or code on the bell housing that will confirm this for you.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 8:23am
I've heard about unstyled WC's that came with ring gear installed from the factory. Guys switched out the bell housing for one that had the starter hole, added a battery and were in business. Some fabricated a genny bracket, too.
WC, CA, D14, WD45
Max(ia) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Max(ia) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 8:57am
My 37 has starter and one wire alternator.  I'm sure it was changed over, because still has the permanent crank.  Has old original 2 fuel carb and make- shift starter rod.  Has to be started from the ground in order to operate the choke.  First thing before starting is lock the clutch down, don't need ran over by a WC.   Beats the hand cranking.   lol
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 12:44pm
My '37 has electric start, and appears to be totally factory.  I'll hafta look closer to verify, but there's indications that this one has never been disassembled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 3:03pm
I have a 35 WC with "factory" electric start, but since it wasn't available until the styled WC's came out I know it was converted.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 3:40pm
I have a 36 that I personally converted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 3:57pm
This guy swears it is factory. I am pretty certain it is not. I will go look at it later and see what I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 4:25pm
Dave, What "indications" are there that is was never disassembled? It would have to have been split to add the bell housing with the starter hole. I Know an older fellow that spent many years working on AC's and he said you couldn't buy a starter conversion kit till 1939. Allis was probably too busy using up starters and bell housing building new tractors to take time to sell a "kit". Late 1938 was the first styled WC and the first electric start WC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 4:36pm
Here is a quote from Norm Swinford's book on AC Farm Equipment. Talking of the "new" 1938 WC "Perhaps the most important change was the new electrical system with starter and lights."
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 6:00pm
well every JD guy needs a tractor that he can depend on . I'm sure it was an original WC electric start , but not on that tractor. guy told me once he had an all original 36 Wc. It had starter, alternater, & muffler went through the hood. Don't think it had a distributer though.But the lights looked pretty neat.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 7:52pm
The electric starter did not come out as "factory" equipment on the unstyled - Flat Top - WC.  I remember my father unloading our first carload of styled WC's in the light snow Thanksgiving of 1938.  If I recall correctly the starters did not have the heavy wire starter rod to start from the foot rest.  Pop had to stand next to the gas tank and press the starter from there.  We didn't care it was great to have electric start.
Later as parts we got the starter rod for a WC and installed them.
Yes, I am certain some have traded out the clutchhousing and replaced the flywheel for a ring gear but officially they did not come out till at least 1938.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 7:22am
I went and looked at it last night. There is a lot of good and bad about this tractor. It is a 35 WC. Nice fenders and one really nice rear round spoke wheel. The other rim is shot. Front spokes are decent. Looks like the rimes where replaced. Some big ugly welds on the spokes. Someone put a distributor on it with lights and starter. Has a newer WD manifold on it with a hole in the hood for the muffler. Tank is nice. Pretty complete. I will end up with it sooner or later. Good start to a project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 8:00am
Go for it! I think it needs to have a new home and some tlc.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 8:16am
Here's what my 35 looked like when I got it home.
Well, that is not the original picture but gives you some idea how bad it was. Transmission case cracked with rusted up gears, front rims rotted off and these were welded on 16 inch rims, rad shot and engine stuck badly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 9:26am
Dave, if he decides he doesn't want it, I will be all over it. I have been looking for an unstyled WC for awhile.
CTucker, looks like a lot of work on that one! Glad to see someone saving it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 12:12pm
The indications I see, are original paint that passes from engine to bellhousing without being chipped, cracked, or broken along the parting line... Apparently never even got a clutch job.
The one thing, however, that MAY be possible, is that mine is very late '37, or perhaps the rearend has been changed.  Perhaps I have a 'rare' bird...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2010 at 10:00pm
If it is a 37 and has electric start, then it was repainted when they put the starter bell housing on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 9:57pm
Could be, but if they repainted it, they took it down to bare metal to do it...
When did they actually start manufacturing the '38 model-year tractors, and when during that M.Y. did they actually start offering the electric?  My guess, by the serial number, that mine's a very, very late '37... and again, it may be that the tractor is actually newer, but the rearend is older...
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2010 at 6:42am
The electric start package was introduced in late 1938 with the styled WC. No unstyled WC's came from the factory with electric start. There were unstyled tractors left at dealers when the new styled ones came out. It is possible that a guy could buy an unstyled WC new in 1939 with a dealer installed starter and bell housing but it didn't come from the factory that way. WC69790-WC74329 were 1938 unstyled without electric start. WC74330-WC75215 were 1938 styled with electric start.
This page was generated in 0.093 seconds.
