Unstyled WC 6 bolt hubs ?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Unstyled WC 6 bolt hubs ?
    Posted: 21 Mar 2011 at 9:28pm
I was given a WC front pedistal today that has 6 bolt hubs. What size tires fit the 6 bolt hubs? Are rims hard to find? Are tires hard to find? Would wd 5 bolt hubs fit these spindles?  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 9:34pm
Any 6 bolt implement rim will fit I think. The problem with a lot of implement rims would be the offset in the rim. I have 6 bolt hubs on the WF right now with rims off an All Crop combine. Tires would be in the 6.00-16 to 6.50-16 range. There is no reason why you can't use 5 bolt hubs on it if you get the right bearings. Heck the bearings might be the same as what's on it now.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 9:59pm
<shrug>  I got it... just drill another hole (hee hee)
So... which models/years were the 5-bolt hubs used, and when were the 6's used?
Edited by DaveKamp - 21 Mar 2011 at 10:00pm
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 10:04pm
Serial #23529-59627(1936-1937) had 6 bolt, 59628 and up had 5 bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 6:23am
Were the original 6 bolt rims 16"?
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 6:31am
Could be wrong,but I thought they were 17 inch.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 7:14am
On the 36WC that I sold a month ago has the 6bolt hubs and it has 16 in tires on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 10:17am
The original front wheels that were 17 in, were F&H round spoke and didn't bolt on. When the 6 bolt hub came into plat, the rims were 16 inch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 6:58pm
Thanks for the help guys. I guess I'm looking for some 6 bolt rims and 16" tires.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 7:04pm
I have a good pair of the correct 16" 6 bolt rims and hubs off of a '37 WC parts tractor. Unfortunately, I'm a long way away from you. Shipping would probably be far more than the parts, which I would probably give you.
This page was generated in 0.242 seconds.
