Unplugged |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3098 |
Topic: UnpluggedPosted: 11 hours 28 minutes ago at 5:33am |
Have a couple two prong power tool cords that come apart too often. Is there a fix besides tying them together? Thanks
Posted: 10 hours 43 minutes ago at 6:18am |
Some (not all) prongs are a folded over design with a slit between them. Take a flat blade pocket screwdriver and spread the slit apart to your liking.
ACinSC
Posted: 10 hours 25 minutes ago at 6:36am |
Thanks Dr Allis! I'll check it out
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6514 |
Posted: 9 hours 48 minutes ago at 7:13am |
I hadn’t thought of spreading the prongs like that but I like that better than bending them a bit as I have done.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34574 |
Posted: 9 hours 6 minutes ago at 7:55am |
We had a Cover that kept the Cords Plugs protected and Connected at the Nuke, was for areas hard to access during power operations, believe that Grainger had them.
Joined: 11 Sep 2009 Location: illinois Points: 88795 |
Posted: 8 hours 53 minutes ago at 8:08am |
Normally it is the FEMALE PLUG that has become WEAK inside and the contacts are spread and not GRABBING the male plug... Same happens with wall sockets when they get old.......... If the plug is FALLING OUT, then the female end needs replaced.
ACinSC
Posted: 1 hour 29 minutes ago at 3:32pm |
Could be the female connection I guess, but I mostly have trouble with my two prong power tool cords. Thanks everyone
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24806 |
Posted: 49 minutes ago at 4:12pm |
cut the 2 prongers off, install 3 prongers ! Yes, teh ground is NOT connected but it gives 'strength' to keep them connected.
ACinSC
Posted: 40 minutes ago at 4:21pm |
Yeah Jay. I've seen adapters so you can use a 3 prong in a 2 prong outlet. Wonder if they make any the other way? Thanks
