Unplugged
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Unplugged
    Posted: 7 hours 54 minutes ago at 5:33am
Have a couple two prong power tool cords that come apart too often. Is there a fix besides tying them together? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 9 minutes ago at 6:18am
Some (not all) prongs are a folded over design with a slit between them. Take a flat blade pocket screwdriver and spread the slit apart to your liking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 51 minutes ago at 6:36am
Thanks Dr Allis! I'll check it out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 14 minutes ago at 7:13am
I hadn’t thought of spreading the prongs like that but I like that better than bending them a bit as I have done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 32 minutes ago at 7:55am
We had a Cover that kept the Cords Plugs protected and Connected at the Nuke, was for areas hard to access during power operations, believe that Grainger had them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 19 minutes ago at 8:08am
Normally it is the FEMALE PLUG that has become WEAK inside and the contacts are spread and not GRABBING the male plug... Same happens with wall sockets when they get old.......... If the plug is FALLING OUT, then the female end needs replaced.
