Un styled wc ?s |
EricSWPA ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: PA Points: 292 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Feb 2012 at 2:01pm |
Im wanting to order a steering wheel is the styled the same? Also mine has the 6 bolt wheels on the front what size tires would these be thanks.
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3866 |
All the unstyled WC's ive seen have a flat spoked steering wheel styled have a round spoked wheel same as WD and WD45
Mine appears to have the round spoke but ive been searching and havent found a new one listed for a un styled and my front tires are basically gone lol. Amazingly the front rims look nice though.
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3919 |
Original front size was 5.50 X 16. on 6 bolt rims and same on 5 bolt.
Thanks one last ? How many gallons of gas does the tank hold i want to line it im guessing ill have to buy 2 of the cans since they only do a twelve gallon tank and im guessinng its a 15 gallon tank thanks
You're right on that one. Ref. book says 15 gallons for both styled and unstyled.
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2572 |
I did a WD tank thats 15 gallons with a 12 gallon kit, worked just fine.
AaronSEIA |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Nobody makes reproduction flat spoked ones for the WC. There are ones out there that can be repaired to like new by http://minnkotarepair.com/steeringwheel.html Call around to guys that part tractors out and find an original. It cost $65 plus the ride to have one redone. |
Don(MI) ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: Michigan Points: 3893 |
Did even the unstyled '38s have a flat spoke just before the style change? Wondering if they did not.
Galatians 5:22-24
"I got a pig at home in a pen and corn to feed him on, All I need is a pretty little girl to feed him when I'm gone!" |
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9656 |
Don My unstyled 38 had covered round spokes and the center hub was coated. I've never seen another like it. I don't know for sure that it was original.
Im not even sure what year mine is i cant read the serial number so i just ordered the round spoked one im thinking i need to find a cheaper hobby lol. I almost have everything i need to get it done. I still need to figure out what im going to do with the rear tires i have steel wheels right now got the rims but there just about junk. But i've allways liked the unstyled wc's looks
Denis in MI ![]() Orange Level ![]() Joined: 15 Sep 2009 Location: Norvell, MI Points: 832 |
I've got two 38s and both have a covered round spoke wheels. Edited by Denis in MI - 24 Feb 2012 at 8:19pm |
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Ray ![]() Orange Level ![]() Joined: 21 Sep 2009 Points: 1979 |
I have 2 flat spoke steering wheels for un styled WC. Would need to be redone>$75.00 785-353-2392 |
The only reason I am thinking they could have used round spoke, is because our family WC had spoke before a restore. It had been painted once since new, so It may have been replaced. But that was many years ago. Good chance that steering wheel in the picture came new on the tractor.
![]() Edited by Don(MI) - 25 Feb 2012 at 7:33am |
Galatians 5:22-24
MBWisc ![]() Silver Level ![]() Joined: 13 Apr 2011 Points: 103 |
Measure the shaft size. The 33-34 had a larger shaft then those that followed. I have a covered one with the for the larger shaft.
Don, What year is that one, 1938?
What diameter is the shaft?
Charlie, yes its a 1938 |
Galatians 5:22-24
