U-joints 80-R3 Sickle bar mower |
Post Reply |
kmw3006
Bronze Level Joined: 04 May 2021 Location: Omaha Points: 9 |
Posted: 04 May 2021 at 1:17pm |
I was given an 80-R3 mower that previous owner didn't need. It had been sitting around outside for years. My first project on it is to change the ujoints. Been talking to 2 different AGCO dealers. One says one size, the other says there is 2 sizes, depending on the shaft, a normal use or a heavy duty use shaft. My questions for now are, is there 2 styles of shaft and how do I tell the difference. Thanks
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8144 |
welcome to forum. put a picture on here. Think the heavy duty was for if you were going to tow a hay conditioner behind mower.
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10551 |
Measure the size of the cross. Diameter of cups, and outside to outside of cups, that will tell you the size. HTH Tracy
kmw3006
kmw3006
There's the pic of shaft parts. The solid piece (slides to PTO) is approx. 11/16x13/16. The hollow (mower) piece is approx. 1 3/16 x 1 1/16, wall thickness 1/8. Working non other measurement.
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1217 |
You may have to get a bit more sophisticated with your measurements. Measure with micrometer to get correct u-joint.
kmw3006
These were the only recognizable symbols on the body of either u-joint. The other joint had Made in USA 24 on the end of the cap |
HD6GTOM
Orange Level Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Take the whole thing to your local NAPA store. If its like ours, they will measure up everything and have you going asap. Buy the better grade u joints. Their cheep ones are Chinese made.
Edited by HD6GTOM - 04 May 2021 at 9:15pm |
kmw3006
I did give that a try, but I they couldn't find one that matched the groove for the retaining clip.
Alvin M
Orange Level Joined: 24 Jun 2018 Location: PA Points: 728 |
Std Part # 70534235 check 12R retaining ring is inside on cup HD is 70521720 check 14R retaining ring is outside of cup
kmw3006
Thanks to all for the great advice so far. Alvin are those AGCO stock numbers or can I take them to other places such as auto parts store. Closest AGCO dealer is an hour away and their hours don't match well with mine. Again thanks to all.
Alvin M
Yes they are AGCO part numbers
Mikez
yes that’s an agco part number
kmw3006
Got the ujoints. one fit real nice, real easy. Other one a bear to get in and ended up ruining it. Replaced it, cleaned yokes up good but was still difficult to get in, but it's done. Got it hooked to the tractor but I'm doing something wrong. Whole thing sits crooked and pivots in toward tractor when lifted. Guessing to fix crooked I have to lengthen the lower left link. Don't see how to get the pivot out
Mikez
what tractor you hooking to. Put picture of it hooked
kmw3006
Hooking up o a Farmall 450. Tryed to link a.picture but keeps saying file to big. I'll keep trying though
Post Reply | |
