Uh oh... 200 piston
TexasWD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasWD45 Quote  Post ReplyReply Direct Link To This Post Topic: Uh oh... 200 piston
    Posted: 02 Mar 2017 at 7:04pm
Well... I ran my 200 for about six hours discing on Tuesday, turned it off for the evening. Next morning started it up and let it warm up for a few minutes (my 200 is cold natured). Put it in first gear to get it moving on to the next field and then! A quite, deep tapping noise from the engine! I turned it off as soon as I heard it. Decided not to start it again but to turn the engine over and see if I could hear where the sound was coming from. Sounds like something in the #4 cylinder, sure enough I towed it back home and pulled the head off. Looks like it blew out the top of the cylinder and threw a ring. Have you guys ever seen anything like this?
'38 B with belly sickle,'52 WD,'54 WD45,'39 WC,'47 B
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 8:09pm
Have your injectors checked would also take a look at you turbo
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 9:05pm
that's nasty looking!
Dek Thorne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dek Thorne Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 6:41am
At least u knew enough to stop
LYNNMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LYNNMN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 11:55am
Had it happen on 1969 gas 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 12:28pm
Gas engine is not the same piston as a diesel. I'm gonna guess starting fluid damage. Check ALL pistons while apart for broken rings or ring lands.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 6:59pm
Better check the rod on that cyl. to see if it is bent. All the suggestions above are relevant. I've seen the inj. do some weird things to pistons.
eighty nine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eighty nine Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 7:08pm
I would agree with the Doctor. You will probably find broken rings on other cylinders as well. Seems common with hard starters & lots of ether.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 9:40pm
Well if you put that back together with a sleeve and piston without going threw your injectors good luck like i said check your turbo also..
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasWD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 7:03pm
Does anyone know how to remove the front axle pivot pin?
Plowjock5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plowjock5 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 7:32pm
There is a snap ring that holds it in place remove it. The pin has threads in the end of it for a 3/8 bolt. Screw a bolt in so you have something to pull on. You will need to remove a tie rod end it's in the way for the pin to come all the way out. Good luck !
