UC Running help needed |
Post Reply |
johnny
Silver Level Joined: 12 Sep 2009 Location: shawneetown, il Points: 317 |
Posted: 07 Jun 2010 at 4:24pm |
I am in need of some help. I have my uc that I bought a while back. I got it running and found it had two exhaust valve seats dropped out of the head and would not let the those 2 exhaust valves close. So I took the head off and had a very reputable rebuilder do the work. We replaced all exhaust valves, seats, and guides, we did the same on the intake side. I put he head back on new gaskets for head, intake, and exhaust. I put on new carb to intake gasket and when I fired it up it run but would accelerate then decelerate kinda like fast slow fast slow I tried to adjust the carb to no avail. I then had the carb rebuilt, the guy has rebuilt many carbs for me in the past and I have never had a problem with any carb, when I put the carb back on I had the same problem again.
I would appreciate any ideas or question you might have to help me figure this out.
thanks
johnny
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Air tube !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
johnny
Just pulled the breather assm apart no blockages and started tractor with no breather connected to carb same thing.
Thanks Johnny |
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
Fred is talking about the air tube in the manifold I believe. It can rust through or burn out causing a loss in vacuum pressure at the carb and I believe sucking exhaust in if I understand it right. My CA wanted to do that too but it didn't have the proper anti surge spring on the throttle linkage.
Ted in NE-OH
Orange Level Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Sounds like a carb linkage or govenor problem.
CTuckerNWIL
When the engine is surging, grab hold of the throttle shaft in the carb and hold it in one place. If the engine runs smooth, the problem is most likely caused by slop in the linkage or governor. If when holding the throttle shaft in one position the surging continues you may have an internal leak in the manifold. I really don't know how the engine would act with the burned out air tube (I'm sure Fred does).
johnny
Thanks for the ideas, Sorry I mis-read you Fred. On the manifold where the elbow comes out and goes up for the exhaust pipe I see two bolts on a larger cover plate. If I take off that cover will I see the problem if it is the air tube inside? I will try holding the carb linkage steady and see what happens.Thanks
johnny
skipwelte
Orange Level Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
On the older ones you have to separate the top and bottom halves of the manifold to get to the air tube, dont know about the later ones. HTH
Post Reply | |
