UC exaust |
Post Reply |
Wot
Bronze Level Joined: 16 Sep 2009 Location: N Points: 154 |
Posted: 16 May 2022 at 11:45am |
Hello,
As far as I can see, the UC has had two kinds of exaust. One trough the hood, and one beside the hood (like a U). What was the reason for the difference? Thought it was when kerosine or gas, but see both in both types of exaust. Thanks! |
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9190 |
If track them in serial # early ones come out at front , later in middle .This how i learned in last 30 years .but sure they got mixed up on the year do to engine n manifold replants
Edited by Fred in Pa - 16 May 2022 at 12:29pm |
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
Wot
Ok, thanks. Could be indeed, ours is a early one and had the exaust through the hood indeed. But it has a cover on the ‘inlet’ (that’s were the higher serials have the exaust) why was that plate? Because it is on the inlet side of the manifold, it can’t be for an exaust or am I wrong?
Fred in Pa
This is a early manifold ,switch elbow with plate when running kero
Fred in Pa
This is later manifold you use a cover with K on it for Kero , and a cover with G for gas
they redirect exthaust
Pfouts Family Farm
Bronze Level Joined: 05 Dec 2018 Location: Hiram, Ohio Points: 170 |
Early style manifold - Has front and middle outlets - Pre 1937 Front for running gas (only the rear 2 cylinders ran past heat chamber - less heat) Middle for Running Kerosene (all cylinders run past the heat chamber - more heat) Swap the elbow and plate to change fuels Late style manifold - Has reversible heat chamber - 1937 and up There is an internal baffle which directs more or less heat to the intake depending on the orientation of the chamber. There is a marking of K and G on the top and bottom of the chamber. K right side up for Kerosene, G right side up for gas. To change, remove the elbow, and the heat chamber, turn the heat chamber to reflect to desired fuel, and reinstall the chamber and elbow. |
Wot
Great bunch of information guys. Thanks for the perfect reply's. All clear now!
Wot
Another question 🙂
I see UC’s with base mount magneto and flangemount (RV4) magneto. Untill witch time the base mount mount was the standard? Mine is a ‘36 and want is as close as orig. thanks! |
Post Reply | |
