U ring gear
KPaul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KPaul Quote  Post ReplyReply Direct Link To This Post Topic: U ring gear
    Posted: 22 Feb 2024 at 9:37am
Hello all...I have a U power unit...the 318 to clarify.
.it's hand start only ...looking for a ring gear and a starter for it...I have it all apart overhauling it and figured this would be a nice upgrade...thanks in advance...Kevin
Mfam8 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mfam8 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2024 at 3:39pm
You do realize you also must have an oil pan that accommodates the starter, correct? They cast the starter hole provision into the pan on the UM engine, so the pan itself is different. A starter from a S, SC, D,or DC   Case tractor will work on the UM engine just fine. (must re reference the set screw hole)  The Ring gear will be the hardest piece of the equation to find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KPaul Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2024 at 5:39pm
Yep it has the starter hole and the set bolt hole...still has the original tin plug in the starter hole
