type of weld,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: type of weld,,,,
    Posted: 25 Aug 2024 at 7:42pm
 What do you call a weld where you weld a piece of 1" angle to another 1" angle back to back to form an X,,,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 7:51pm
hmm, an Xcellent question !
if it hold, a great weld !
if it fails, a &*%*&(%&*%(^$%$@#%#$$(&*^&)(*)(*_&)*%$&(^%_&^) weld .
OK, maybe an 'hourglass' ??
Hay, I tired . Had to hand shovel a YARD of busted concrete off MY driveway  and into the 'Porch Project', don't ask why. All I know is my arms still hurt and NOBODY has said 2 words to me that HIS mess has been CLEANED up...
BTW be sure to clamp the steel down good ,weld, and DO NOT remove the clamps UNTIL the steel naturally cools down. Failure to not do this WILL result in the piece warping,go cockeye, bend, be USELESS......
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 3:16pm
If they were point to point of the 90s, I believe it would be a butt weld.  If you position them so that one was slid up the back of the other so that two legs were inline across from each other I believe it would be a fillet weld.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2024 at 9:12am
 Well,,I need some 1" X 1" X 1/8" pieces of the "X" shaped metal for a project ,,,Checked out McMaster-Carr but no luck,,,,,Anyone got a clue,,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 10:05am
 Well, I think I might of worded this request wrongly,,,,Wink
 What I need is the name of the metal or configuration of this that forms a " cross " with the four parts of the cross to be equal length,,,?
  Who sells this type of metal or where to locate some of same,,,?? Many Thanks,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 12:43pm
Im not sure i have seen such a design. I would not be structural as there is no strength in that design and not useful in any construction.. It could be a design or architecture piece, but i have not seen anything like that.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 2:46pm
Confused I am lost as is normal. So be gentil with me when tell me I am crazy.Ouch
But why can't you weld the 2 angle irons together? You place outside of the angle back to back and you have the cross with equal "arms" in all direction. Unless you need hundreds and hundreds of feet of it no big deal.
Wink And as with everything this day and age you can buy steel here off the confuser O'h I mean computer. Some place out here in the clouds, blue sky somebody had a link, and I bit. Every other add was for steel ( thank God I don't get as many adds as some seem to). But now all realest or weed killers.LOL So if you're brave enough, or is it dumb enough use your search for steel whole sale an see if you can find what you're looking for.
Now that I moved on in comes the add Metal Depot is one place. Find out if they do free shipping on a 20 foot stick of anything.LOLLOLLOL
Edited by Ray54 - 02 Sep 2024 at 2:51pm
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 4:13pm
Cruciform section?  Not sure if it's readily available but I think that's what it'd be known as.
I think as suggested, if it's small volume you may be better off gluing it up yourself.
This page was generated in 0.301 seconds.
