Two Twenty oil filter
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Topic: Two Twenty oil filter
    Posted: 11 Oct 2022 at 1:30pm
Hello,
I want to change the oil filters from my 220, but can’t find any nummers on it. They are overpainted.
Also in my books I can’t find partnummers.
Does someone of you know the numbers from agco or another brand?
Are they the same as for a late 7060?
Thanks.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 1:57pm
NO Agco part # is 74027979
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 2:14pm
I have 2 agco #74035556 and 2 donaldson #P550152 filters in stock for my 7060.
From outside mesurements they look the same, would they fit?
Or should I get ordered the number you said?
Thanks!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 2:26pm
7060 are not interchangeable unless your 220 has a newer engine in it. Are the filters on upside down (can fill them before installing) or right-side up (could not fill them first)? The D21/210/220 and many others use the 74027979 which has 3/4-16 threads, the 7060 used 74037047 or 74035556 with 1"-16 threads.
Edited by injpumpEd - 11 Oct 2022 at 2:36pm
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 2:44pm
Thanks, the filters are right side up. It has the correct 220 engine.
Last question… do you know the donaldson of baldwin numbers for the 74027979.
Overhere I can’t get fast agco parts.
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 4:29pm
Baldwin is BT267 Donaldson is P553411
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2022 at 9:28pm
Got a pair last year for my 220 from AGCO and the have the AC logo. They were from the vintage line so there's a V after the pt#. Didn't ask for it just ended up with it. Kinda cool but that's not something that matters to me. They even tightened up with the logo showing. Of course they're upside down....
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2022 at 12:55am
Thanks, great help here on the forum.
