Twin charger 301 |
Post Reply |
190xt llss
Bronze Level Joined: 04 Jan 2019 Location: Kansas Points: 12 |
Posted: 08 Jan 2019 at 5:31pm |
I’m building a llss 190xt with a 301 I’m looking for suggestions on a twin charger setup
Acllss puller
Bronze Level Joined: 02 Oct 2013 Location: Ny Points: 181 |
Call Dennis at FVP !!!! Smalll s400 and a gt45 on top maybe, just call him .
Acllss puller
Head and flow will be your problem . Can be improved with extreme work !
Orange Level Access Joined: 12 Sep 2009 Points: 19716 |
WHAT ARE YOUR RULES ???? Some organizations only allow a maximum inlet/outlet size !!
190xt llss
I can run any two turbos. No intercooler. Water injection. I might add I’ve already got the head work done and custom exhaust and intake housings to let it breathe better.
So, how many CC's of fuel and what type of injection pump and injectors do you have? You can run bigger turbo's with 1000 cc's versus 700 cc's of fuel. I assume you are open RPM's ??
190xt llss
P-3000 capable of 760cc 4x30 injectors yes open rpm
bsallis180
Silver Level Joined: 29 Jul 2013 Location: Pennsylvania Points: 207 |
Doc no intercooler? Over 1000cc on 301inches?
So a 190XT with any size twins and 760 cc's of fuel should need a gear waaaay faster than direct drive road gear ? Yes or No ?? Under 7000 lbs ??
190xt llss
10% over road gear 6400 lbs
190xt llss
If I can build the power for a faster gear then that’s where I’ll go
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7984 |
Any videos? Sounds like a good one
Acllss puller
Power to be had with the newer injectors with 5 hole or even 6 hole !
KevinON
Orange Level Joined: 07 Dec 2009 Location: Schomberg, ON Points: 786 |
Best of luck in your build! I am building a 7000lb Super Light Mod Farm 190XT right now, but my next build will be a twin charger 301. Cheers.
Acllss puller
A 180 in direct is 22.7 you should be able to get at least that fast 21.6 would be good if your doing it all ? Good luck
190xt llss
I’ve got 10 over gears and going with 20.8’s
Post Reply | |
