Turning Up A Pump On 8030 |
DennisA (IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ridott IL. Points: 2064 |
![]() ![]() ![]() ![]() ![]() Posted: 14 May 2011 at 5:09pm |
We have an 8030 that seems to be lacking power. Thinking about taking pump in to get checked out. I was wondering if the 8030 & 8050 had the same engine. If that is so than we could turn up the pump to put out 150 hp. What do you think?
Thanks & God Bless
Dennis |
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1213 |
8050 had an intercooled engine (670I), don't think the 8030 did, pretty sure it had the 670T (only turbocharged).
Hurst
1979 Allis Chalmers 7000
5800 Hours |
Carl(NWWI) ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: NW WI Points: 954 |
Should have the same pump, should be a American Bosch Model 100, 13mm pump, unless 8030's & 50's had 11mm, not sure, but anyway, the top cover on the pump, should be 4 1/4 inch bolts, take them out, pull cover off, the screw will have a 7/16 nut, and have a flat head tip on the end, loosen the nut and turn the screw out a 1/2 turn, or 1 turn, depends on how much power you want, i think its 50hp and turn, or in that area.Good Luck, Carl
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 4997 |
ALL model 100's used on 8000 series AC's were 10MM.
I was told the 8070's had 13's
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Correct. If my memory is correct, the 8030 only had a 2 pinion differential while the 8050 had a 4 pinion. I can't remember if the planetaries were the same or if the 8050 was also wider than the 8030. Increase the hp at your own risk. |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Sorry, 9.5mm I guess, so they must call em 10mm. still the same to turn em up though, still not sure on how many horse a turn is.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21081 |
8050 has a larger (more tooth length) ring and pinion, 4-pinion differential and final drives that are the same width, but faster gear ratio. If the injectors have 4,000 or more hrs on them, replace the tips before you start increasing the fuel delivery of the injection pump. When those Bosch injectors wear, they will increase the smoke levels AND the HP drops, and increasing the fuel delivery only makes the smoke heavier and does not increase the HP of the engine....been there.....seen it!! Adjust new injectors to 3600 psi instead of 4,000 psi plus as the book says.
This 8030 does not smoke at all. When you load it down the exhaust stays clear. |
Thanks & God Bless
Dennis |
WD45 ![]() Orange Level ![]() ![]() Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 952 |
Will these engines start better in cooler weather if the injector pressure is set at 3600 psi instead of 4000 psi. |
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
the head in your pump may be worn out! We have seen several M100's lately that have worn hyd heads, so fuel delivery is low, but they still start. have you had tractor on a dyno? sounds like the pump is due for rebuild.
Steve M C/IL ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
@4900 hrs my M100 was shot.No gov action down low,lots of smoke and wouldn't start hot.
IH used these pumps befor AC and they called them (2500 hour pumps). MACK
I wonder if today's ultra low sulfur fuels are causing more pump and nozzle wear in the older units not designed for ULSD?
Mark
