Turning Distro without changeing timing |
MadCow
Joined: 27 Aug 2023 Location: South Dakota Points: 174 |
Topic: Turning Distro without changeing timingPosted: 12 hours 12 minutes ago at 2:48pm |
![]() For some reason my distro is 180 degrees off, so my tach drive isn't facing the right way. I "should" be able to turn it in increments of 60 degrees as long as I change which sparkplug is plugged where, right? Or do I need to pull it completely and turn it and retime? I will be timing the motor regardless, but I dunno really want find TDC. |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54854 |
Posted: 11 hours 33 minutes ago at 3:27pm |
Is it a D series tractor?
MadCow
Posted: 11 hours 30 minutes ago at 3:30pm |
Sorry, 190xt
Joined: 11 Sep 2009 Location: illinois Points: 89567 |
Posted: 10 hours 50 minutes ago at 4:10pm |
normally people want the #1 plug wire in a specific location.. if you dont care, then yes you are right.. rotate the distributor and cap 180 degrees and move the wires the same... It all depends on where the ROTOR is pointing and it will move 180 degrees with the distributor.
Posted: 8 hours 47 minutes ago at 6:13pm |
This much, I know. The distributor rotor/shaft cannot be turned 180 degrees. It only fits in the engine one-way, not two ways. So, with that in mind, proceed.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34463 |
Posted: 4 hours 2 minutes ago at 10:58pm |
Tach drive was forward on all 190/XT gas tractors as far as I know.
