turn signals on the '28 Chev
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: turn signals on the '28 Chev
    Posted: 23 Sep 2024 at 2:57pm
Anyone have any idea what the lens might have been made of!
the 'lenses' is some sort of plastic like material sandwiched between two metal discs that ore riveted together. Opaque in the front lights, red in the rear. I'm pretty sure thee are after market, but still have been on this truck for a very long time. I would like to rebuild them if I can.
Interesting, the curled up mounting piece on this one is not present on the left side.
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 3:15pm
Yes: Aftermarket for sure. Back in 28 a turn/stop signal was various contortions of your left arm. I'm sure that would be most likely some sort of plastic, slightly possible thin glass. I'd think if you could carefully remove the rivets, you'd find there was just a colored disc of some translucent material. Colored Lexan or plexiglass would be a possible replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 3:44pm
Actually, one single stop light was stock, but, as you say, turn signals were supplied by the driver. I'm in the process of dismantling one as we speak. you are correct, it is some sort of plastic like material. If you look close at the pic, the original material has cracked and curled as though subjected to hi heat, but I doubt it was actually HI heat, more likely IV from sun
Wait for the Lord;
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 6:33pm
Find someone in the theater production industry. They used colored filters on the stage lights. Probably not uv stable for long term but these vehicles would likely be stored inside most of there remaining life
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 6:42pm
I sent you a link for a replacement glass insert.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 7:30pm
Thank you
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2024 at 11:47am
Nice truck! I have a set of after market turn signals that the previous owner added in about 1945. The plastic was bad like yours. I was lucky to have a friend give me two front and two rear lights with the plastic in good shape. I put new bulbs and sockets in them and everyone likes the look. I like having the safety of the turn signals. Even though they are not true to the year of our 32 Ford big truck.
 Good luck.
 Chris and Cheryl
Edited by Sugarmaker - 28 Sep 2024 at 11:48am
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2024 at 3:48pm
 Good luck.
 Chris and Cheryl
Did you mean Wink 65 rather than 45?  I ask because I can remember when all the old farm trucks had to be updated with turn signals out here and it was mid 60. Cause my rememberer did not start working until 58 to 60. I remember the handle up top behind the drivers door with cable to metal strip with reflectors on it for turn signals. So unless your truck started in rich folks business, no frugal farmer would changed until gubberment said you had to. The only disadvantage I can think of was they did not self cancel after the turn. And the clicky,click was not that loud. So many a farmer drove for mile with it blinking.
