Turbocharging a 185
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Topic: Turbocharging a 185
    Posted: 29 Aug 2010 at 7:55am
Thinking of throwing a turbo on the 185.  Any tips from anyone that has done this?  Thanks.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 9:08am
Kevin, Fred Dunlop in Stayner has one.  Sounds sweet!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 12:18pm
Those 301,s love a turbo, easiest way I have done it is to get everything off a 190 xt or 200, you get the bigger air cleaner, tube, exhaust manifold, crossover tube ,oil lines , etc, they all match up since they both have the 301 diesel ; I put one on a 180 and it stays cool with the 180 radiator , you,ll have to cut out a new hole for the xhaust , and dont weight it down and work it real hard or you will pop the rear end, I go a gear higher maybe a little bigger disc, brushogg , etc,  ;  works great !!
jerbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbear Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 5:16pm
We had McKim's at Oskaloosa, IA put a turbo on our 185 from an M2 combine.  Runs real smooth and sounds good with a straight pipe.  Dynos 100 hp without touching the pump.  As long as you're not gonna do heavy work with her, you should be fine.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 6:04pm
How much increase gallons per hour burnt over the standard 180 setup?
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 6:29pm
adding turbo should reduce fuel useage
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 7:33pm
Thanks, guys.  I only want a few more ponies for pulling a 16' cultivator and a 4/16 plow, etc.  Would adding one set of pie weights be too much with calcium?  Thanks again.
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 8:46pm
I have a 180 and the toughest job it has to do is when we put it on the liquid manure pump. Our JD 3140 has about 100 HP. and the 180 can almost pump as much manure as the 3140. Would like to put a turbo on the 180 to get a few more horses out of it. PTO work is the hardest work it does, it revs up to about 2000 RPM before it smokes too much so that is where we run it. Will the transmission handle it?
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 10:13am
"you,ll have to cut out a new hole for the xhaust "
 Don't have to if you put the turbo on so the exhaust is headed backwards. Will come up right in the same hole,  but you will need to modify the oil lines and air intake hose to do that.
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 11:14am
We used to do some of them at the dealership, to help make the turbo live you need to install an oil cooler. If you can get the engine setup from an all ready turboed unit great. If not we installed a hydraulic oil cooler form I beleive a 200 in the stock location in front of the radiator and plumbed the turbo feed and return lines through it.
Pullin With AC
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 11:47am
Hey if the N6 can get 145HP out of a 301 then that 185 should hum!
Charlie
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 12:01pm
301 in an N6? maybe an L?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 12:17pm
Charlie is confused.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 3:32pm
N6 had a 426 at 220HP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 4:45pm
well it was one of them! :0
Charlie
