Turbo for 7020 |
youngorange2000 ![]() Silver Level ![]() Joined: 27 Mar 2019 Location: eastcentral MN Points: 308 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Apr 2021 at 4:34pm |
so last sunday I was planting alfalfa and it was pretty dusty and the then the tractor started chattering pretty badly and I found that the hose clamp holding the intake hose on the turbo snapped in half and the hose popped off and was sucking dirt pretty badly. I had only been planting for about 45 mins. my question is what new turbo would be the best for it? I am hoping to avoid cheap chinese garbage, is there a "mordern" upgrade that works well or should I be looking for a reman garett? Thanks
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 19734 |
WHICH HOSE ?? The 3 inch diameter hose that goes over the radiator?? or the smaller 2 inch hose that crosses over the top of the valve cover ??
If it was the 3" hose, I would be more concerned about engine than turbo. Turbo will stand more dirt than engine. MACK
the hose that came undone was the main intake hose coming from the filter, I am not concerned about the engine as we had the same exact thing happen to a IH 5288 we owned we just replaced the turbo changed filters and oil and away it went for 6000+ hours before we sold it at 11,000 hours. again my question is should I be looking for a more efficient modern turbo or should I stick with a reman of what it has?
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1206 |
Stick with what it has. It's an efficient engine and already pushing out 150hp (at the flywheel) from 301 cu inches. That's pretty good for a tractor engine, especially of that era. I would spend your money on buying a quality unit designed for it. A bad turbo can take out an entire engine. Check with your local diesel shops, they can usually get you a factory reman from AirResearch/Garrett turbo for a reasonable price. I had to do that on my 7000 10 or so years back when a tree limb caught the muffler and broke the exhaust housing on the turbo.
Hurst
1979 Allis Chalmers 7000
5800 Hours |
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
I had my turbo rebuilt at a turbo shop.
