Tube Type? |
BenGiBoy ![]() Orange Level ![]() ![]() Joined: 11 Nov 2015 Location: Ashville, NY Points: 701 |
![]() ![]() ![]() ![]() ![]() Posted: 06 May 2025 at 3:48pm |
I am currently working on getting new tires, tubes, and RimGard with Multi-Seal in it on my B (1939). I failed to change the valve stems in the old tubes full of calcium chloride often enough and what do you know... leaks.
![]() While looking at tubes I came across some with an offset valve stem. Do I need that? Or just "regular" tubes will work? These are the ones I was looking at getting if they are right: http://justubes.com/products/two-7-5-24-8-3-24-9-5-24-9-5x24-8-3x24-7-5x24-farmall-cub-tractor-tire-inner-tube-tr218?_pos=1&_sid=d920559b7&_ss=r Thanks in advance, and sorry if this is already here, I looked but didn't see anything, but I might've missed it....
Edited by BenGiBoy - 06 May 2025 at 3:48pm |
'39 Model B
Tractors are cheaper than girls, remember that! |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3797 |
i put tubes in all the tractor and impliment tires with or without calcuim
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4683 |
Good luck finding good quality tubes today. About 10 years ago I put better tires on a 1975 White 2-60. It still had the original back tires, so I got new tubes. The one new tube leaked from the start, fixed 3 times in 2 weeks. Finaly put the old tube back, been good ever since. The tube had never had liquid of any kind in it.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 2981 |
I have not had problem with modern tubes. Maybe I'm livin right
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21412 |
Radial tubes cost a little more but are heavier/thicker.
All good to know, thanks! I read somewhere that Firestone are the only tubes worth buying, but I'm not sure if that's actually the case or not.
On a side note, I ordered in some Petlas 9.5-24's and have discovered why on a few different threads I looked at trying tofind out info people complained about the sidewalls... The actual tread bars are only 8.5" ish so no matter what the sidewalls are getting abused.
'39 Model B
nella(Pa) ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3114 |
I put a new 18.4 34 Carlisle tire and a new Firestone tube in it, the next day tractor was just sitting there and the tire went flat because the valve stem tore loose out of the tube. The rubber was very thin like a bicycle inner tube, took it back to the dealer and he replaced it.
Wow, I guess that the Firestone's can't be the most amazing tubes ever then. Bicycle thin is too thin for anything larger. We'll see how good the ones I ordered are I guess.
Ordered some BKT tires and sent the Petlas ones back so we'll see, hopefully they are real tires instead of skimpy things.
'39 Model B
Jim.ME ![]() Orange Level ![]() Joined: 19 Nov 2016 Location: Maine Points: 960 |
If the hole in the rim is offset from center, you want tubes with offset stems. Holes in the center of the rims need tubes with centered stems. You do not want to strain the stem to reach the rim hole, or you risk failure sooner than later.
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2262 |
I ordered tubes for my White from a place in Colorado. Also for my drop deck trailer running bias tires. I'll look back through the files to find the vendor. I think the tubes were made in Taiwan but they are very good quality from what I can tell. Originals were Firestone in both applications and these match in thickness and quality. I do have calcium in the tractor tires and they don't seem to leak.
That's All Folks!
Well, I now cannot seem to find any tubes for 9.5-24 tires that specifically mentions being offset including ones listed for B's so I guess I hope the whatever I got work well.
'39 Model B
Tenn allis ![]() Bronze Level ![]() ![]() Joined: 24 Nov 2016 Location: Tennessee Points: 133 |
If your rims are good enough why not go tubeless we fought tubes for many years and always had to break a tire down to fix it
Then we started buying tubeless tires with 4 silage wagons of 6 tires each running up and down a 4-lane you can pick up a lot off stuff and if the hole is small enough just plug it and roll on not to mention we ran 6 hay flats then also Almost all our tractors and equipment have tubeless now except for the front tires on our sprayer could only get that size in tube type and earlier this year had a little piece of wire go thru the tire broke it down and fixed it 3 days later flat again I had pinched the tube fixed it again another 3 days flat again another piece of wire fixed another time so far still holding good luck and God bless |
