Tube Type?
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Topic: Tube Type?
    Posted: 06 May 2025 at 3:48pm
I am currently working on getting new tires, tubes, and RimGard with Multi-Seal in it on my B (1939). I failed to change the valve stems in the old tubes full of calcium chloride often enough and what do you know... leaks. AngryAnyhow, I figured that now was the time to do it right. I was going to go tubeless but one of my valve stem holes has cancer, so I figured I would go with tubes instead of welding just in case I messed anything else up more while I was doing that.
While looking at tubes I came across some with an offset valve stem. Do I need that? Or just "regular" tubes will work?
Thanks in advance, and sorry if this is already here, I looked but didn't see anything, but I might've missed it....
Edited by BenGiBoy - 06 May 2025 at 3:48pm
'39 Model B
Tractors are cheaper than girls, remember that!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2025 at 4:16pm
i put tubes in all the tractor and impliment tires with or without  calcuim
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 41 minutes ago at 11:21am
Good luck finding good quality tubes today. About 10 years ago I put better tires on a 1975 White 2-60. It still had the original back tires, so I got new tubes. The one new tube leaked from the start, fixed 3 times in 2 weeks. Finaly put the old tube back, been good ever since. The tube had never had liquid of any kind in it.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 21 minutes ago at 11:41am
I have not had problem with modern tubes. Maybe I'm livin right
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 15 minutes ago at 11:47am
Radial tubes cost a little more but are heavier/thicker.
