Tube or tubeless tires for my 1961 D15?
Gunn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gunn Quote  Post ReplyReply Direct Link To This Post Topic: Tube or tubeless tires for my 1961 D15?
    Posted: 23 hours 12 minutes ago at 7:17pm
I have a 1961 D-15 Hi-crop tractor (s/n: 3801). I am getting ready to purchase new 12.4-38 tires for my 38x11" rims (see photo). These are not the current wheels on my tractor.
I'm trying to determine if I need to purchase tubeless or tubed tires. Are these rims compatible with tubeless tires? I'd prefer to go tubeless if possible.
I am planning on sand blasting and painting the wheels before adding the tires.
Thanks,
Tom
1961 D-15 Hi-Clearance
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 60 minutes ago at 7:29pm
If your rims are solid and not rust pitted from being fluid fill tubeless tires will work without problems. Give your rums a good close look after sandblasting before you repaint them and spot weld any holes that might appear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 49 minutes ago at 7:40pm
check the hole size where the valve goes... Make sure you get a valve that FITS.. or you might have to drill the hole alittlel bigger..
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 36 minutes ago at 7:53am
I put a new pair of 18.4x34's on my 756D last summer, mounted tubeless. Just this week I put a tube in the right one. It just would not stay up. Very slow leak but annoying all the same. So the tube went in the tire/rim that looked almost factory new. And yes, I wire-brushed and painted the inside surface. No obvious puncture found in the tire. Left rim, which has some pitting, seems to be fine. If it starts to leak, it will get a tube pronto. Had it to do over again, tubes right out of the gate! Tried to save a few bucks, you know.
Edit; I should add that mounting them tubeless was not fun. Had to wrap a strap around and crank it as tight as possible to get them to 'take'.
Edited by IBWD MIke - 10 hours 33 minutes ago at 7:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 32 minutes ago at 7:57am
I just can't imagine going tubeless on a farm tractor rear tire or any farm implement tire for that matter.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 31 minutes ago at 8:58am
i would never have a tractor tire mounted up tubeless even if it was just to parade and show
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 20 minutes ago at 9:09am
I've got tubeless planter,grain cart,field cultivator 545B wheel loader and combine tires. Prefer tubes on tractors and recently had to mount a loader tire. PIA. Big rachet strap around center. Good way to get hurt trying to release ratchet.
This page was generated in 0.273 seconds.
