TUBE ASSEMBLY 229367 D19 |
WD45
Joined: 20 Sep 2009 Location: STAYNER,ONTARIO Points: 957 |
Topic: TUBE ASSEMBLY 229367 D19Posted: 20 Sep 2024 at 10:43am |
Wanted one Tube assembly 229367 for D19 item 1 on page 195 of D19 March 1964 dealers parts book.
This is one of the lines for power steering.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Posted: 20 Sep 2024 at 12:25pm |
Checked all my sources, NLA - no NOS... D15D D17 D19 all use this , sorry.. looks like inverted male flare - either make one or salvage yards.
ryan(IN)
Joined: 11 Sep 2009 Location: Bluffton,IN Points: 789 |
Posted: 20 Sep 2024 at 12:56pm |
If there’s enough straight section of tube on both ends you could get compression fittings that then crimp to hydraulic hose to get it made.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
WD45
Posted: 20 Sep 2024 at 4:25pm |
I had to cut the tube above the 90 degree bend to put a socket on to get the fitting out.
Tube was leaking at other end. Had a hose made up but the fitting was too long causing the hose to rub the steering and radius rods.
