tsx 464 |
jkoepke
Topic: tsx 464Posted: 02 Apr 2012 at 12:23pm |
working on a tsx 464 carb today pretty rough shape. Does any body know what size of tap to use on the nozzle jet to clean out the threads and also on the economizer jet. the nozzle jet i have screws in from bottom with screwdriver not from top with nut type driver thank you
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 11992 |
Posted: 02 Apr 2012 at 2:30pm |
Best thing to do there is pick yourself up a steel ball brush that goes in a drill. This is what I use on our customer's carbs when I rebuild them. It removes all the rust and debris that gets lodged around that tube in the canal, and it also cleans the threads out quite nicely. You don't want to run a tap down there when you're going to re-install that nozzle with the brass machine threads. Taps remove material, and that nozzle will be real loose going back in. The steel ball brush does an excellent job of shining up the threads and getting that nozzle canal cleaned out. I use the same ball brush to clean out the rust and debris in the inlet to the needle valve, and also the bowl drain.. HTH |
Dave Richards (WV)
Joined: 14 Sep 2009 Location: Fairmont, WV Points: 881 |
Posted: 02 Apr 2012 at 2:58pm |
