TSX 464 Carb
Wyocrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wyocrew Quote  Post ReplyReply Direct Link To This Post Topic: TSX 464 Carb
    Posted: 05 Nov 2021 at 10:04pm
I'm in dire need of help. My carb on the wd45 is puking fuel out of the air cleaner intake after I stop cranking it over. I can't get it to start. I did put a rebuild kit in the carb and it doesn't start leaking fuel till I try to start it and a bunch comes out once I stop cranking. Any advice Is greatly appreciated. I have horses that want fed once I can get it running.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2021 at 10:38pm
Let's put your horses first this time :) Turn off the gas by the sediment bowl. Pull out all the spark plugs, use your propane torch to dry off the plugs. If you have an air hose handy blow air into each cylinder for a few seconds, if no air hose, crank the engine over for 15 seconds or so BEFORE you put the plugs back in. Once you have the plugs back in proceed to start the tractor like normal WITHOUT turning on the gas. The tractor should start and as soon as it does turn on the gas and go straight to feed the horses :). Let's hope the float/needle hang up is temporary, if not, you may need to open up the carb and carefully check the needle/float function. If the tractor starts as suggested above but runs rough as if it's getting too much gas, take a hammer and tap gently on the side of the carb, this may correct the 'hang-up'. Please let us know when your horses are fed and happy LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2021 at 1:08pm
I should add this to my words from last night that I have had very much the same scenario with my WD at times and it wasn't necessarily that the needle was stuck open BUT that good sparks were compromised to the point where the tractor didn't start fast enough and then the gas started dripping out by the intake. Of course, once the plugs are wet and the cylinders are overloaded with fuel everything needs to dry out before it will start. If your problem continues you should check and make sure you have good quality sparks. Please let us know your progress.
