TSX 464 carb refurb (WD series) |
Page <1234> |
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2682 |
Chris just do a search for the paint. Seems to be quite available.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8534 |
mdm1,
Yes I did find it on line too. Thanks, Regards, Chris
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2573 |
What a great informative post! Thanks y’all!!
Blue Skies and Tail Winds
Dana |
Folks,
Ok grab a coffee and kick back testing the new camera on this carb build. As mentioned I just wanted to get this together so I chose not to strip it again. The paint will look ok. So the assembly begins: installed the power jet that I broke and got out. I put a little oil on the threads when installing these items: ![]() small jet put in upper body: ![]() Seat for needle valve and its gasket: ![]() throttle shaft and new rubber seal, plus retainer: ![]() Throttle plate in position: I had not installed the low speed screw yet. Made sure the plate looked good and fit good, in the bore prior to tightening the screws. Used just a little blue Loctite on the threads, ![]() Installed low speed jet: ![]() Venturi was not in the rebuild kit: ![]() Float was adjusted by placing a rod near the pivot point and very gently pushing down on the floats. Then checked for the 1/4 inch dimension from gasket the float with same rod. ![]() ![]() Emulsion tube and gasket and main high speed valve and gasket: ![]() Emulsion tube in home position: ![]() ![]() Choke rod felt seal and new retainer: ![]() Choke plate installed: ![]() Screws and lock washers attach the two halves together: ![]() High speed adjusting valve in place: ![]() I choose to use the drain cock vs the brass plug. This allows the gas to drain easily if needed. ![]() TSX 464 complete except for brass gas inlet elbow: ![]() ![]() ![]() Paint match is close enough for me. ![]() Comments always welcome. I may have made some mistakes? Good to point those out too. All in all this was probably the best carb re-build I have done. Thanks for the help along the way too! Now we need to "test on it" this spring! Regards, Chris |
Your post made me think about some of the air filters on my tractors. Guess I will be cleaning them out. Good work and thanks for the progress pics.
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12007 |
Chris,
I'm not pickin' on yer' job. The Carb looks great and your assembly & pics were great, but I noticed in the one pic looking down that inlet bore going to the needle valve looks rusty in there. It's important that the inlet is super clean. Dirt, rust, and debris gather in the rear of that cavity, and that crap gets hung up under the Viton needle causing a flooding issue. I always run a bore brush on a hand drill down that cavity like I do in the nozzle bore and make sure I clean the threads with the bore brush to get rid of any rust in the threads that will get into and stick to the Viton needle valve. I get that bore nice n' shiny. If its just the pic that makes it look that way then disregard my comment. I'm a little anal when I rebuild stuff. LOL! Carb should work fine I would think... Forgot to add, I usually crank the air/fuel mix screw about 1 1/2 turns, and the enrichment needle about 2 turns for a starting point. Once you get the engine up to normal operating temp you can dial in the Carb accordingly at idle and at WOT. HTH Steve@B&B
Edited by Steve in NJ - 14 Jan 2020 at 7:04am |
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Did you polish the inside of the venturi or did it just clean up that good? If you did polish it, good thinking.
Dave(inMA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Another question that might expand thinking about carb rebuilding. In another of my worlds (Model A Fords) we flow test the jets when rebuilding a carb as the kit jets often deliver too much or too little gas. Anyone ever see flow specs for jets like these and/or test the jets?
WC, CA, D14, WD45
Steve,
I probably could have done a better job of cleaning the insides of some of the areas. In this case I was lacking the proper tool (brushes), maybe lasy and impatient too! Although a rifle bore brush may be the tool your referring to? Do you have any pictures? The screw setting s sound right. The paper work with the kit said one turn out. I usually go 1.5 turns to begin. Chas, Just fine steel wool on the venturi. Dave, Steve may help us on the flow testing? I dont have a clue. But I do wonder about jets and sizes? You always hear about opening up jets for additional carb tuning. I am just a parts changer at this time. Regards, Chris
Chris,
I can send ya a pic of the different brushes that I use to clean these bores out. A lot of muck and debris from old fuel, contaminants, and such get settled into these cavities. That's why its so tough getting some of these jets or nozzles out. In my Carb kits, I don't supply jets. In most cases the jets are fine if removed with the correct tool, but if a jet is damaged or breaks removing it, I always put the same jet back in as I took out unless I'm building a pulling Carburetor for a customer, but that's getting into a whole another subject. I know what Dave is referring to on the Model A Carburetors. Most of those that are on Model T, A, & early B motors are updraft Zeniths. A little bit different from Tractor Zeniths, but the principal is the same. They're enrichment systems are a little different, and depending on the mfr. of the Carburetor kit, in a lot of cases, the jets are not always the same as what came in the Carburetor's originally as Dave mentioned. Sometimes you have to drill out a jet for those particular Carbs to the next size up depending on which engine its on and model Carb. I believe ole' Henry used a couple different model Zeniths through the 28-31 A Bone years. I also rebuilt a Holley many years back for one of my Model A customer's. My BIL is supposed to be sending up his Carburetor off his 31 A Sedan that he drives everyday to work down in Wildwood Crest where he lives. He drives his all year round. He's probably having to much fun driving his Tudor to remove the Carb to send it up for a rebuild! LOL! Steve@B&B
Steve,
Thanks. I think tips like your cleaning tools would be good for us DIY guys. I am still hooked on mid 50's Fords. Yea I am a Ford guy and was just checking out 56 Victoria on Facebook market place. Do I nee one? No! But we had a 55 Crown and I know most of the pieces on one. Somedays I miss it. Other days not so much as I reinvented myself into the Allis world of toys! Regards, Chris
I have a Victoria. Its an early one though. Henry introduced the Victoria in 1930. Mine is a late 31'. Although, the first engine I ever rebuilt was in a 56' Crown Vic. I was 14 years old working for an older gentlemen that had an auto repair shop. I believe it was a 312 V8. I was proud of that engine when that thing fired up for the first time. My first engine rebuild. Even though I was starting to turn into a Chevy guy little by little.... LOL!
Steve@B&B
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
Steve, do you paint the inside of the carburetor. also? I have a theory that despite fuel filters, the carburetor itself generates junk through rusting. Sooner or later it gets plugged or stuck. And as little as 7 years may be the time frame, with E10 fuel. Asking the group, how long do your rebuilds/clean outs last on the MS carbs?
Steve, Folks
Wife says she is leaving if I buy another toy (car)! Dang I will miss her! I found a driver not a show car 56 Vic. Would be another money pit. The engine you rebuilt probably was a 312. Or it could have been a 292 which was debuted in 56 I think. The Thunderbird had a 312 in 56 I believe. Just have always liked those old Ford Y blocks. Not a great engine but they sure sounded good! I remember hearing a friend drive his two tone green 56 past my place and the sound of the duals was just awesome. That was 1967. I had my 55 crown for about 30 years it was in bad shape. Bought it in 1971 for $50 with no engine or trans. Lots of work over 6-7 years. That was mid 70's, sold that one in 1997 after I had done a shade tree restoration and did get it on the road for a year or two. Then it set with engine out for rebuild for years. Kids in college and needed some cash. Life has its issues. Ok I feel better! Regards, Chris Edited by Sugarmaker - 15 Jan 2020 at 6:12pm |
garden_guy ![]() Orange Level ![]() Joined: 05 Jul 2013 Location: Illinois Points: 1152 |
Chris, Oh wow great thread! I have the smaller Marvel carbs on my older WDs (with the main and idle jets both up on the top side) and the 2 turns and the 1 and 1/2 turns worked great for a starting point. However I am working on a WD-45 right now that has this TSX 464 carb and I had never seen the single screw on top and the weird mix screw on the bottom with the 90 degree bend it in. Just curious where you settled on how to adjust it? This tractor hasn't run in 8 years and the carb was fairly clean, just some light rust inside. I found the top screw was about 3/4 of a turn from bottomed out. Haven't tried the filter adjust screw as I wasn't familiar with it and didn't want to damage anything. Will tinker with it and get a few pictures to post later.
GG,
I believe the adjustment on the lower front of the carb (TSX464) is the main jet. I would look in the book first, but I usually set them 1.5 turns out to start. Since I have pulled my WD45 a couple times I would generally turn that "L" shaped adjuster out a turn when I was pulling. Fast forward to a month ago and I thought to myself which is generally dangerous, maybe should turn that main jet back in. So I did. Next time I started the tractor it would run but only for a short time then stall like it was running out of gas. Checked tank, had fuel, took off the sediment bowl and cleaned. Still had same issue. Start and run and stall. Choking it helped. Humm, turned the idle jet out one turn, and it was just fine! Good luck on your carb refurb! Regards, Chris
Edited by Sugarmaker - 26 Apr 2020 at 2:09pm |
Thank you Chris, it reminds me not to starve the fuel to an engine as, it is cheap compared to a rebuild from running a engine to lean.
Edited by chaskaduo - 26 Apr 2020 at 3:10pm |
GG,
I would recommend getting the kit from one of the supplier. I used Sandy Lake and was very pleased with the parts included! Regards, Chris
Brian, The only inside part of the Carbs I paint is the inlet to the venturi. If you paint the inside of the Carburetor where the float bowls are, the gasoline will just eat the paint right off instantly, and you'll wind up with a mucky mess that will eventually ruin your rebuild by plugging up idle circuits etc. Chris, The wifes T-Bird has a 292 in it. First year T-Birds had the 292 and were 6V. Coarse it ain't 6V anymore. Runs pretty darn good to I might add. Hey, ya never know. You might wind up with another Crown Vick! You might wind up divorced, but hey no big deal. I did that a couple times.... LOL! Now I have a wife that doesn't give a crap what I bring home as long as she can drive it and its fast! They say three's a charm..... LOL! Steve@B&B
Fortunately everything looks in good enough shape other than some rust in the base and a bit of gunk in the main jet, it seems not bad. Cleaning her up, will put in a new gasket and probably see if the tractor will run with it at this point. Will start with 1.5 turns out on both screws and see what we get. Suggestions to scrape off the remnants of the old paper gasket material without scratching the casting? ![]() |
GG,
You can use a putty knife. Razor blade works the best. You're not gonna hurt that casting that's fir' sure unless you take a grinder to it. LOL! I use a Roloc pad on my 90 degree air dremel. Cleans up the surface nice once ready for assembly... Steve@B&B
Steve is right on the money there. I use a soft 3M scotch brite type wheel on a small air die grinder to gently buff the mating gasket surfaces.
I also understand that if the pieces are still functional and not worn they can be cleaned and reused too. As I read back through some of this thread, I did forget to check that float in water for leaks!:( oops hope that doesn't come back to haunt me? Regards, Chris
If the float pontoons weren't sloshing with fuel in them, you're probably okay in that department. If there's dents in them from ice (water in the fuel bowl over the years) that sometimes can stress out the pontoon seam and eventually one of the pontoons could take on fuel later on. I always change out the old floats for customer's when they have dents or a big dent when I assess the Carburetor for a quote so they don't have that issue down the road. Especially after I just rebuilt the darn thing for them! LOL!
Steve@B&B
Steve, Folks,
My float looked good with no dents. But this carb came off ebay and may have sat for years without gas in it. I hope we can get it on a tractor this spring and see if my rebuild was sussecful. Thanks for the support! Yea I still like those old Fords! We need some pictures of your toys, maybe the Vicky? GG hows the carb coming along?? Regards, Chris
Well Chris, I did some more cleaning on it yesterday, and used a razor
blade to scrape off the old paper gasket remnants. I don't think the
carb was sealed up well before it sat for 8-9 years, as there was a lot
of dirt and rust present in a few spots. Lots of nasty stuff peeped off.
![]() Carb cleaned and air blasted it and all the passages seem clear at least. |
GG,
That is looking way better! I like to scotch-brite the mating surfaces. Or if you have a fine stone (machinists) you can use that to 'flatten' the mating surfaces and remove some of the roughness. Should run good! Regards, Chris
Thanks Chris. I think I'll do a light pass with the scotch brite just to make sure. Then a last flush and dry with carb cleaner. There's a couple spots of rust -- one in the bottom of the right bowl, and one where the drain plug goes, that I want to try and scrape out so it doesn't flake off later. Then re-assemble that, and move on to cleaning the gas tank, as I fear it is plugged up with gunk as well. I've got a new sediment bowl screen and gasket. Then once we get fuel going, we'll switch over and check points/distributor and see how she looks.
Anything else you think I should take out and clean? This is how far I've stripped it down (when I started to razor blade the gasket off) ![]() |
I'm about to start a similar project. Can see what I think are the main nozzle and the power adjusting needle seat still installed in your photo. - I'd remove them if you can get them out w/o damaging them. The throttle plate is still installed along with the throttle shaft bushings - the bushings are often worn and are the source of an air leak that messes with the air/fuel mixture.
Side note - I haven't gone back to re-read this entire thread to see if this is mentioned, but the parts kit I just opened indicates that there are three versions of the 464: fixed jet and two adjustable main jet versions. Interesting. Chris's, yours and mine are all type C with the L-shaped adjustable main jet.
WC, CA, D14, WD45
Rick of HopeIN ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1329 |
I have a sand blast cabinet but use it less often these days. More often just use wire wheel on angle grinder and a smaller rotary grinder with wire wheel for big stuff. Smaller stuff just sandpaper and scotch brite.
I have done minor rebuilds on a lot of carbs but never took one down that far, thanks for showing how its done. For the small engine stuff, I find the parts harder and harder to come by. Some of the kits are really just gasket sets. |
Page <1234> |
