Trying to identify year of tractor
Jemak1234 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jemak1234 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 6:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jemak1234 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 6:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jemak1234 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 6:51am
Based on the serial numbers on block and by shifter - can anyone tell me the age?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 10:22am
Based on the curved gearshift, it is either a later 1952 WD or as new as a 1957 WD-45. The serial number for the chassis is directly above the left side square headed bolt just above the rockshaft on the rear face of the rear end housing. It is stamped and will say WD XXXXXX. The number you have provided is a raised "casting" number and really means nothing to me. The serial number for the engine is also stamped and is directly behind the hose that runs from the air cleaner to the carburetor. It will say W-xxxxxx for a WD engine or 45-xxxxxx for a WD-45 engine.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 2:24pm
What happened to throttle quadrant?
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 3:12pm
The posts were from April of 2017 so I assume the tractor is long gone.  He last was on the forum April 4, 2017.  Must have found a home for the tractor.
Edited by JohnColo - 15 Sep 2021 at 3:14pm
1951WDNWWI View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1951WDNWWI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 5:46pm
Tall head on a WD makes it a 1951 or newer if original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jemak1234 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 8:03pm
The Block serial is WD 35448 4PA  The 4PA is raised slightly from the others
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2021 at 8:13pm
So, it's a late 1952 or up to mid 1953 WD. It is not a WD-45 unless you give me the chassis S/N.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jemak1234 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2021 at 8:25pm
I can barely see some of the serial number on the rear differential exactly where it was described to be, but there is too much paint to make it out.  Any thoughts on best way to remove the paint without messing it up too much?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jemak1234 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2021 at 8:28pm
If anyone has a lead on some rear tires, I am need of 2 decent tires and I think I have 2 salvageable rims... but I'll have to see when I change them.  I have a spare rim that is good with another bad tire on it.   I have an extra bucket if someone needs one.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2021 at 8:44pm
If the manufactured year of the rear is that important to you and have any access to a black light, wipe clean the area good with alcohol. The uncleaned depths in the stamping will become visible with the UV bulb in a very dark setting. Please remember that motor swaps were very common due to interchangeability for these tractors. End of the day— curved shifter indicates late wd though 45 time period trans. Tall head and no engine plate, most likely a 226, can be checked with wire in spark plug hole for stroke verification..
Edited by allisbred - 16 Sep 2021 at 8:46pm
Mbressie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mbressie Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 1:23pm
I'm trying to date my tractor. The only numbers I'm seeing are WD 245030 and WD 40246.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 2:48pm
WD40246 is 1950
WD245030 is 1957
Edited by dfwallis - 26 May 2024 at 2:49pm
1952 CA13092
