Trying to figure out a D17 hydraulic issue...
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Topic: Trying to figure out a D17 hydraulic issue...
    Posted: 15 Mar 2024 at 9:22pm
So I've got a buddy who has a D17 that he doesn't know a ton about. It has a front end loader, and it runs. Apparently the front loader works just fine, but he has a rear blade for it but when he puts it on, it won't lift the blade up off the ground. He tells me several years ago it used to work, but one day it quit working so they took the blade off and have just been using the front bucket.
I don't know anything about D-17s (my knowledge stops at WD-45 stuff), but I had him send me some pictures (it'll be an hour drive for me to go investigate in person, so want to get some info in advance). Looks like a similar setup to a WD-45 with a 445 loader with the hydraulic pump run off the crank. So I'm assuming there's 2 hydraulic reservoirs? Anything simple to look at that would make the rear lift arms not work, like low fluid or stuck linkages or known issues with hydraulic pumps?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2024 at 9:38pm
A series 4  ????    The tall lever on the front of the console makes the arms go up (pull back) and down (push forward). Has he checked the hydraulic oil level ??? dipstick to the front left of the gear shift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2024 at 10:03pm
Yeah wish I had a better picture of the series number there. The fluid level is definitely first thing on my list to check.
Do these have a second reservoir for the loader hydraulics, or is it all just that one reservoir?
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2024 at 10:12pm
The tractor is a series 4. The reservoir for the loader is in the left side loader upright. I can see the lines in the photo. Your issue is with the tractor system only. Check the fluid level like Dr says. Then next is the hyd valve itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 4:04am
Don't forget to check the TB linkage, those 2 levers on the right, last picture, linkage is prone to freezing from rust, and its a tricky adjustment, anyway...Wink
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 7:54am
Pulling either of the two shorter levers should make the engine labor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 7:20pm
So those back two levers are the TB setting? And then the two short ones (by the tall one) are the remotes? And if I pull the remotes with nothing plugged in the pump should run and pull the engine down?
Also, oil recommendations? Just standard Hy-Tran type stuff these days?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2024 at 8:17pm
Yes.Yes.Yes. No. Yes.
