Trucking Recommendations
PDehring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Topic: Trucking Recommendations
    Posted: 20 Aug 2020 at 9:19am
Need a 175 moved from about 30mi north of Terre Haute IN to Owosso MI.  Does anyone have anyone they would recommend for hauling?
1937 M Crawler, 1963 D21, 1964 D21, 1965 D12 SIII, 1970 220, 1976 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 7:25am
If the rear wheels are "spun" clear in against the fender, it will just barely slip in-between the fenders on some low-down trailers. Front tires must be in as well. Trailer needs to have two 5K axles or larger, as the tractor with no fluid or weights will weigh 6K.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 7:31am
That's currently the issue, the rear tires are spun out and the front axle is spread out.  The rear tires are loaded as well so weight becomes an issue as I only have a 1/2 ton truck.
Keith M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith M Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 8:10am
I just found out that Fastenal has a service called Blue Lane Freight. They will ship store to store. Go to Fastenal.com scroll to bottom of page to Compliance and Sourcing. It’s on right side of this option. You can get help there as to rules for shipping.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 8:24am
I got a tractor hauled from Mass. to Va  by putting it out for bid on USHIP,
doesn't cost anything unless you get it hauled.Got a bunch of high bids early on but then the bids got lower,I took the 2nd lowest bid it sounded like he'd do a better job.Turned out to be a real nice fellow and did a great job at a  decent price.I kept his phone number but he only hauls on the East Coast.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 8:46am
Thanks, it is listed on uShip currently but I've had mixed results with uShip.  Just wanted to put a feeler out here to see if anyone knew someone they knew would do a good job, trusted, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 9:28am
With tires out it will need an 8ft 6 inch wide trailer and it could actually be overwidth  !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PDehring Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 11:20am
No, they are at about 90", don't need an overwidth trailer.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 12:54pm
*******Depending on the Pandamit 19 I may be down in that area toward the end of next week....Dale
Orangereborn
Dale Schafer
964 192nd Ave
New Richmond, WI 54017
715-247-3079
Cell 715-781-2055 Text
Orangereborn@hotmail.com
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 1:18pm
Orangereborn (Dale Schaefer) would do a good job for you.  He always has for me.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 1:45pm
Dale is the best! He has hauled many pieces for me. Always satisfied.   Tracy
Wayne180d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne180d Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 4:46pm
Dale is very good and a great guy
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 6:35pm
It's too bad Harold over in Chesaning passed.  He moved some stuff for me.  I don't know what he charged as I was the seller.  A really nice guy that has been missed dearly for several years now!
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2020 at 7:51pm
Ditto for Dale as well. He hauled a 185 for me from Egg Harbor Wisconsin to Corydon Indiana and did a super job. A fine  Fella.
Gando View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gando Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2020 at 1:18pm
Can you PM me the nice fellow's contact info Please?
I am looking at a WD45 that is 325 miles away on the east coast.
The transportation is the only thing holding me back
Thanks
Gando
midwestmac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote midwestmac Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 7:04am
This is a good guy to have in your contacts for hauling.  He is out of central Iowa but he gets out east with loads.  He has a 30ft+ trailer.  102 wide.
Ty Brekke
641-849- 7077
Bird76Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 1:21pm
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 2:15pm
Use Dennis Anderson on this site. Used him twice very top shelf
If someone needs his contact info I can PM it.
Edited by victoryallis - 27 Dec 2020 at 2:16pm
This page was generated in 0.091 seconds.
