Truck of the month
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Topic: Truck of the month
    Posted: 03 Apr 2021 at 6:19pm
the truck on my calendar for the month of April is a Iveco 4x4 fertiliser spread with side tipping trailer this is what most farmers use to put lime and fertilisers on with .hope you all have a great Easter
Tractors Allis EB,two C,diesel G
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 2:04am
So it's 'outstanding in it's field' Jeff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2021 at 1:50am
never seen an IVECO spreader truck around here, mosty GMC/Chevy/sterling/navistar ones. and none pull trailers, the companies use truck tenders. had one roll over near here yesterday, spilled all it's load, took turning around to fast in the field.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2021 at 3:57am
Problem with fertilizer trucks of any variety os corrosion
All metals dislike the aggressive actions of fertilizers, longevity is short where in the US the use of older trucks has been typical as they have already passed that point of disregard for age.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2021 at 6:42am
Same here. We use an 85 C70 for chicken litter. The key to fighting rust and rot is keep it dry. Park it under a roof and don't haul wet litter. You can wash the cab but not the bed. The bed that's on our truck is about 10 or 12 years old and still looks fairly new. It's a 14ft Chandler. They make a damn fine bed.
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2021 at 10:43am
Was inspecting a chicken layer operation once, and at the maintenance shed, mechanic was working on wheel bearings on a litter spreader truck.
He said the litter was pretty light, but truck wouldn't make it a mile down the road before it had so many flies on it the weight was unbearable.
He might have been kidding........or not.
Top dressed hay ground earlier in the week, used a pull type buggy from the fert dealer.  Between use, abuse and corrosion, those things get the crap kicked out of them. 2 of last 3 I have used have had mechanical breakdowns with me using them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2021 at 11:19am
He was kidding
Wheel bearings on these trucks take a pretty good beating because of the terrain they're used in. Just about every pasture and hay field I've been on here has terraces and rocks you can't see until you hit them and holes you can't see. Also you have to move at a pretty good clip to do it right so it makes the rocks and holes and terraces a bit more rough. And these trucks are pretty well worn out before they become spreader trucks
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2021 at 2:21pm
when we worked at the pig confinment, the trucks that brought the new pigs in were the fanciest straight trucks that you could buy. hauling them pigs musta paid real well. as the truck owners said they don't last much more than 3 years tops. before each load the trucks have to be acid-ized top to bottom, inside and out, under them, everywhere. then they are junked/traded and new ones bought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2021 at 3:52pm
IVECO is a BIG truck manufacturer in Italy.. They make a lot of DIESEL engines also... Real popular in Europe , Australia and a few other places... not so much in the US.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2022 at 5:23pm
Spammer aside, the problem with fertilizer trucks these days is you need an armored car to haul the $ to fill the fertilizer truck!Wink
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2022 at 10:20am
Filling up the fuel tank is as bad as putting the fertiliser in the back of the truck diesel $2.90 a litre +road taxes. DAP fertiliser about $1700 a tonne
This page was generated in 0.175 seconds.
