Truck dilemma
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: Truck dilemma
    Posted: 26 Oct 2025 at 12:33pm
I recently purchased a 2011 ford super duty truck. It has a 6.7 diesel with 192k miles. I bought this truck for a farm truck not an everyday driver. It looked nice and seemed to run excellent, I thought it would meet my needs. After getting it I spent $960 having a gooseneck hitch installed. I also spent around $800 fixing minor issues I found. But I found one major issue, an upper oil pan leak.   This was a big job requiring the transmission to be dropped, to much for me. I found a guy to fix it for $2500. He found a few other issues so it ended up costing about $4000. He also found another problem he did not fix. Metal shavings in the fuel filters. He says the entire fuel system needs replacing. If not, there will be catastrophic engine failure. He explained to me that fords have a poorly designed fuel injection pump that wears out and contaminates the fuel system. A common problem with fords. So I’m at a crossroads with this truck. I’ve already got more in it than it’s worth. I could try to sell it as is and lose thousands I’ve invested and have no truck. Or I can spend more and fix it. It’s probably going to take close to $10,000 to replace the fuel system. Naturally I wish I never bought this truck but I can’t do anything about that now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 2:34pm
I met a Ford dealer yesterday at a tractor pull that was telling me all about how he specializes in only Ford diesel trucks. He had 2 of the HARLY DAVIDSON (HoundDawg) edition specials on a trailer that were only used as pull trucks. And he was pulling the trailer that hauled both with a Newest and latest KING RANCH 4 door. So my guess is that there is plenty of money to be made in the repair business of Ford diesels. Of course I don't know of any Ford diesel lover that their truck doesn't  spend more time at the shop than on the road.
  If I was in your shoes with what you've described, I'd unbolt the hitch and remove anything of value and that truck would somehow catch fire out back somewhere and then a call to the insurance agent would be made.
 Just sounds like owning a boat: a hole in the water to throw money into.
 The other option would be to pull the motor for the boat anchor that it is and replace it with a Cummins. The make adapters to put the Cummins into Fords and Chevys, but I've never known anyone to put a PowerJoke or Duracrap into a Dodge.
 My ideal truck would be a Chey/GMC Cummins powered with the Allison 10 speed auto.
Edited by PaulB - 26 Oct 2025 at 2:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 4:04pm
I’ve heard about the Cummins swap but I don’t know of anyone who has ever done it. I’m sure it’s not cheap either. I’m going to ask around and see if it might be worth it. In that case I would just drive the truck as is until the engine went down and then do the swap.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 4:13pm
https://www.google.com/search?q=Injection+pump+failure+in+pickups+-+type+of+pump+and+resulting+damage&rlz=1C1CHWA_enUS627US627&oq=Injection+pump+failure+in+pickups+-+type+of+pump+and+resulting+damage+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCjU5Mzg1ajBqMTWoAgiwAgE&sourceid=chrome&ie=UTF-8
Diesel pickup injection pumps can fail catastrophically, and the specific failure type and resulting damage vary based on the pump design. The most common types of high-pressure injection pumps in modern diesel pickups are the Bosch CP4, the Bosch VP44, and the Bosch CP3.
< jsuid="TaUOI_b" ="0" -amic="true" -icl-uuid="020cf8fa-f296-45d7-a801-c97f4624368a" aria-label="View related s" ="rBl3me" js="click:&TaUOI_a|S9kKve;mouseenter:&TaUOI_a|sbHm2b;mouseleave:&TaUOI_a|Tx5Rb" -wiz-attrbind="=TaUOI_a_C5gNJc;=TaUOI_a_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIARAB" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Bosch CP4< jsuid="TaUOI_h" ="0" -amic="true" -icl-uuid="3a48a20d-2d0f-4e4d-879b-3b4d42712f41" aria-label="View related s" ="rBl3me" js="click:&TaUOI_g|S9kKve;mouseenter:&TaUOI_g|sbHm2b;mouseleave:&TaUOI_g|Tx5Rb" -wiz-attrbind="=TaUOI_g_C5gNJc;=TaUOI_g_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIAhAA" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
This high-pressure common rail pump is used in many Ford, GM, and Ram diesel engines from the 2011 model year onward. < jsuid="TaUOI_k" ="0" -amic="true" -icl-uuid="ac5dbb14-ab08-4b22-900a-7d640aa9db81" aria-label="View related s" ="rBl3me" js="click:&TaUOI_j|S9kKve;mouseenter:&TaUOI_j|sbHm2b;mouseleave:&TaUOI_j|Tx5Rb" -wiz-attrbind="=TaUOI_j_C5gNJc;=TaUOI_j_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIAxAB" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
  • Typical failure: The CP4 is particularly susceptible to failure due to the insufficient lubricity of American ultra-low sulfur diesel fuel. This can cause the pump's roller lifters and internal pumping components to wear prematurely and generate metal debris.
  • Resulting damage:
    • "Grenade effect": Once a CP4 pump fails, it sends a shower of fine metal fragments throughout the entire high-pressure fuel system.
    • Fuel system contamination: The debris contaminates the fuel injectors, fuel rails, fuel lines, and fuel tank. Flushing the system is often insufficient to remove all the particles.
    • Extensive repairs: Catastrophic failure typically requires replacing the entire high-pressure fuel system, costing thousands of dollars. < jsuid="TaUOI_15" ="0" -amic="true" -icl-uuid="2e5f889d-4a2c-4f7b-9ed3-7a555b4404ab" aria-label="View related s" ="rBl3me" js="click:&TaUOI_14|S9kKve;mouseenter:&TaUOI_14|sbHm2b;mouseleave:&TaUOI_14|Tx5Rb" -wiz-attrbind="=TaUOI_14_C5gNJc;=TaUOI_14_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIBBAF" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Bosch VP44< jsuid="TaUOI_1d" ="0" -amic="true" -icl-uuid="626c47bc-00d4-42be-a131-e50782f2df30" aria-label="View related s" ="rBl3me" js="click:&TaUOI_1c|S9kKve;mouseenter:&TaUOI_1c|sbHm2b;mouseleave:&TaUOI_1c|Tx5Rb" -wiz-attrbind="=TaUOI_1c_C5gNJc;=TaUOI_1c_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIBRAA" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
  • Typical failure: The VP44 has two main failure modes:
    • Electronic failure: The electronic control unit (ECU) on top of the pump can fail from heat and vibration, leading to a "dead pedal" condition (loss of throttle response), rough idle, or hard starts.
    • Mechanical failure: Inadequate fuel supply from a failing lift pump can lead to poor lubrication, causing the rotor to seize and the engine to stall.
  • Resulting damage:
    • Catastrophic stall: A mechanical failure can cause the engine to stop abruptly while driving.
    • Overheating and engine damage: A failing lift pump starves the VP44, causing it to overheat. Ignoring this can lead to poor combustion, overheating, and excessive engine cylinder wear over time.
    • Injector damage: If the pump fails to deliver the correct amount of fuel, it can cause problems with the injectors and poor engine performance. < jsuid="TaUOI_2z" ="0" -amic="true" -icl-uuid="01227c99-605c-4f68-b3a9-898d129f89ec" aria-label="View related s" ="rBl3me" js="click:&TaUOI_2y|S9kKve;mouseenter:&TaUOI_2y|sbHm2b;mouseleave:&TaUOI_2y|Tx5Rb" -wiz-attrbind="=TaUOI_2y_C5gNJc;=TaUOI_2y_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQICBAH" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Bosch CP3< jsuid="TaUOI_37" ="0" -amic="true" -icl-uuid="6d7c5a3c-ba0a-4c53-94a4-a0abd44865bd" aria-label="View related s" ="rBl3me" js="click:&TaUOI_36|S9kKve;mouseenter:&TaUOI_36|sbHm2b;mouseleave:&TaUOI_36|Tx5Rb" -wiz-attrbind="=TaUOI_36_C5gNJc;=TaUOI_36_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQICRAA" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
This high-pressure pump is known for its durability and was used on many GM Duramax and some Cummins diesel engines, notably prior to the adoption of the CP4. < jsuid="TaUOI_3a" ="0" -amic="true" -icl-uuid="b41d4bfb-80f2-41dc-b449-c5be95f27777" aria-label="View related s" ="rBl3me" js="click:&TaUOI_39|S9kKve;mouseenter:&TaUOI_39|sbHm2b;mouseleave:&TaUOI_39|Tx5Rb" -wiz-attrbind="=TaUOI_39_C5gNJc;=TaUOI_39_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIChAB" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
  • Typical failure: While more robust than the CP4, the CP3 can still fail from:
    • Worn components: Over time, internal components wear out, leading to insufficient fuel pressure.
    • Contamination: Water or debris in the fuel can cause premature wear or clog internal parts.
    • Pressure regulator failure: The fuel pressure regulator on the pump can fail, causing idle surging.
  • Resulting damage:
    • Engine damage: A severe failure can produce metal contamination similar to a CP4, requiring the replacement of the entire fuel system.
    • Performance issues: A failing CP3 will primarily cause poor engine performance, such as low fuel pressure, hard starting, misfires, or surging. < jsuid="TaUOI_41" ="0" -amic="true" -icl-uuid="a9f75c3a-a95b-4eb6-95cd-a8a876099f8e" aria-label="View related s" ="rBl3me" js="click:&TaUOI_40|S9kKve;mouseenter:&TaUOI_40|sbHm2b;mouseleave:&TaUOI_40|Tx5Rb" -wiz-attrbind="=TaUOI_40_C5gNJc;=TaUOI_40_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQICxAH" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Common symptoms of any injection pump failure< jsuid="TaUOI_48" ="0" -amic="true" -icl-uuid="6879f1ef-c33d-43e0-9879-968912352b43" aria-label="View related s" ="rBl3me" js="click:&TaUOI_47|S9kKve;mouseenter:&TaUOI_47|sbHm2b;mouseleave:&TaUOI_47|Tx5Rb" -wiz-attrbind="=TaUOI_47_C5gNJc;=TaUOI_47_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIDBAA" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Regardless of the pump type, a failing injection pump typically causes a range of performance issues that serve as early warning signs:< jsuid="TaUOI_4b" ="0" -amic="true" -icl-uuid="499fd311-85c5-4fcb-b0ca-73776135d9a1" aria-label="View related s" ="rBl3me" js="click:&TaUOI_4a|S9kKve;mouseenter:&TaUOI_4a|sbHm2b;mouseleave:&TaUOI_4a|Tx5Rb" -wiz-attrbind="=TaUOI_4a_C5gNJc;=TaUOI_4a_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIDRAB" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
  • Hard starting or no-start conditions
  • Loss of engine power and reduced acceleration
  • Rough idling or engine misfires
  • Excessive exhaust smoke (black, white, or blue)
  • Reduced fuel efficiency
  • Unusual noises, such as knocking or whining
  • Illuminated "Check Engine" light or other fault codes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 4:18pm
Seems the New and Improved injection pumps have a great failure rate and when they do they contaminate the full system with impending disaster from tank to pump, lines , injectors and finally bank account .
 But remember they meet the government environmental outcome of preventing air pollution - dead trucks pose no problems
Truck engine or brand of body - SAME PROBLEM WITH PUMPS across all .
Even the filter used is of no use once pump starts it's demise of wear .
Edited by Coke-in-MN - 26 Oct 2025 at 4:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 5:30pm
I'm sure the Cummins swap will not cost what the Ford fix will be and you'll still have a PowerJoke.
  Just get a Cummins that was before the 98.5 year in a Dodge or a full mechanical industrial or medium duty truck truck engine. Anything that is computer controlled will end up problems in the long run.
 If you are really serious, I have a 5.9 VE rotary pump engine I'd consider selling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 6:11pm
I do have the CP4 fuel injector pump on my truck.   I’ve been told by countless people that they are junk and ford should be sued over them. It would have been nice to had this information before I bought the truck.   I can’t understand why ford super duty’s are so popular. I see them everywhere
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2025 at 7:09pm
Ford’s marketing program is one reason for the popularity. And they dodge the lawsuits because the pumps fail after the warranty expires. A lot of people buy the trucks for a status symbol and trade/sell them before they hit 100k miles. Since this is a known defect I feel that Ford should be forced to cover the repair costs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 7:49am
The CP4 is particularly susceptible to failure due to the insufficient lubricity of American ultra-low sulfur diesel fuel.....
THANK YOU GOVT RULES AND REGULATIONS... Sue them !!
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 11:34am
Ranse, sorry to hear of your trucks issues. Thats very frustrating.  Ford should have done better…. Definitely not living up to their advertised slogan, “Built Ford Tough..”
So my question about a 2011 F250 / F350 is; Does it have good enough bones for its 6.7 to be rebuilt or for a Cummins swap??
My reply would be no. The 2011 has numerous other issues besides its 6.7. You or others might think otherwise?
And that’d be understandable because a new 2025 F250 MSRP begins at $53k towards of $80k…..?
Depends, but you may want to “punt” on this 2011? If so, could try for the 1999-03’ F250 & start there? Or older yet, for mostly mechanical type reliable farm truck.
I did a 97’ p-pump 5.9 Cummins swap into my 2000 F350 7.3 6 speed @ 275k miles. I acquired good used 170k engine from wrecked D2500($2300), Fummins adapter, engine mounts($2400), Dodge flywheel & starter ($1000), & hired independent mechanic to swap engines & etc($4200). Mechanic did an electric fans for radiator setup. It did ok empty but not pulling a trailer. So I fabricated (DIY) the radiator/intercooler/AC condenser forward 2 3/8” to allow for engine fan clearance. Problem solved. These prices were from 2014 @ $10k to do the swap.
End result, I Love the truck!! Mileage now at 333K. Mechanic also installed a jac-brake after turbo that coins with its 6 speed manual. Very nice setup.
19-22mpg empty, 13-14mpg with empty flat gooseneck, 9-10 mpg 275 bu gooseneck grain trailer.
PM me for more detail.
Edited by AC7060IL - 29 Oct 2025 at 12:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 4:16pm
Thanks for sharing your Cummins swap story AC7060IL. I’ve asked a few people about it but no one who knows much about it. Looks like you spent close to 10 grand on a 14 year old truck. I understand, you probably figured it was cheaper than replacing it. That’s kind of where I’m at too. Is it cheaper to go ahead and pay for the extra repairs than to replace the truck? The money I’ve already spent I figure is lost either way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 7:02pm
Ranse... what all do you get for $10k  "system" ......is there any down side to  "run till failure" and then do the FUEL system, or does it destroy the ENGINE itself.. ?
Edited by steve(ill) - 29 Oct 2025 at 7:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2025 at 7:42pm
Ranse, Check out this video of Dave @ Dave's Auto Center talking about the 6.7 powerstroke. He has other 6.7 videos too. Maybe just browse them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2025 at 2:00am
Have two friends that did the swaps, both stated even as has proven a Great set up, the costs exceeded the value.
Had a boss in 1978, had a 1971 Ford F350 SRW Crew Cab as plain jane as they come, defined Industrial Truck we all called the Green Dragon.  He worked and lived outside Sparta IL, took the 300 6cyl out, adapted thru friends of his that worked the Coal Mines around there, a 3/71 Detroit Diesel with a OD Unit so could make speed as only ran half the 300 rpm.  Toured the US camping and sightseeing in it with his gal Friend of close to twenty five years(She was married to a different man).  18-22mpg, SCREAMED LOUD even as had muffler at Highway speeds but he loved the old truck.  He had run it for almost 35 years when he finally had to eliminate it due to rust away.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2025 at 10:05am
<span style="color: rgb0, 0, 36; : rgb254, 252, 212;"> It’s probably going to take close to $10,000 to replace the fuel system</span>
</span>
<span style="color: rgb0, 0, 36; : rgb254, 252, 212;"><b style="">Ranse... what all do you get for $10k  "system" ......is there any down side to  "run till failure" and then do the FUEL system, or does it destroy the ENGINE itself.. ?</span>
the fuel system kit usually includes the fuel injector pump, injectors, fuel lines, and rails. The prices on these kits vary. The one we are looking at is $5800 ( aftermarket). Labor depends, I can’t do the work. The mechanic that did the other work was supposed to figure out a price for me but he hasn’t got back with me yet. He’s never done a fuel system before but he’s full of convenience that he could do it. He generally charges $95 an hour to work on diesel’s but he said he would quote me a flat rate for the job. I’m also going to check some other places as well. I’m hoping it can be done for around 7 to 8k. If I decide to do a Cummins swap ( and that’s a big if) then I would just drive the truck until the engine fails.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2025 at 11:24am
Hearing this makes me glad I went with the 7.3 gasser in my new one. Yea,, I know they have had problems too,, but hopefully not as expensive as the diesel, and it will pull whatever I got to tie on the back of it,,,if it's to big for it to pull,,,, prolly needs to go behind the Ole 359 Pete anyways 😉
Hope ya find a solution that's works for ya
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2025 at 2:24pm
congrats on your new truck Michael V. You’ll be ok until the warranty runs out. Better get the extended warranty just to make sure lol. I wish I had went with a gasser as well. I thought buying an older truck a diesel would be the best choice. You can get more miles out of them. I guess that was my first mistake.
