Truck dilemma |
Ranse
Joined: 11 Mar 2016 Location: Tennessee Points: 779 |
Topic: Truck dilemmaPosted: 9 hours 42 minutes ago at 12:33pm |
I recently purchased a 2011 ford super duty truck. It has a 6.7 diesel with 192k miles. I bought this truck for a farm truck not an everyday driver. It looked nice and seemed to run excellent, I thought it would meet my needs. After getting it I spent $960 having a gooseneck hitch installed. I also spent around $800 fixing minor issues I found. But I found one major issue, an upper oil pan leak. This was a big job requiring the transmission to be dropped, to much for me. I found a guy to fix it for $2500. He found a few other issues so it ended up costing about $4000. He also found another problem he did not fix. Metal shavings in the fuel filters. He says the entire fuel system needs replacing. If not, there will be catastrophic engine failure. He explained to me that fords have a poorly designed fuel injection pump that wears out and contaminates the fuel system. A common problem with fords. So I’m at a crossroads with this truck. I’ve already got more in it than it’s worth. I could try to sell it as is and lose thousands I’ve invested and have no truck. Or I can spend more and fix it. It’s probably going to take close to $10,000 to replace the fuel system. Naturally I wish I never bought this truck but I can’t do anything about that now.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5160 |
Posted: 7 hours 41 minutes ago at 2:34pm |
I met a Ford dealer yesterday at a tractor pull that was telling me all about how he specializes in only Ford diesel trucks. He had 2 of the HARLY DAVIDSON (HoundDawg) edition specials on a trailer that were only used as pull trucks. And he was pulling the trailer that hauled both with a Newest and latest KING RANCH 4 door. So my guess is that there is plenty of money to be made in the repair business of Ford diesels. Of course I don't know of any Ford diesel lover that their truck doesn't spend more time at the shop than on the road.
If I was in your shoes with what you've described, I'd unbolt the hitch and remove anything of value and that truck would somehow catch fire out back somewhere and then a call to the insurance agent would be made. Just sounds like owning a boat: a hole in the water to throw money into. The other option would be to pull the motor for the boat anchor that it is and replace it with a Cummins. The make adapters to put the Cummins into Fords and Chevys, but I've never known anyone to put a PowerJoke or Duracrap into a Dodge. My ideal truck would be a Chey/GMC Cummins powered with the Allison 10 speed auto.
Edited by PaulB - 7 hours 40 minutes ago at 2:35pm |
Ranse
Posted: 6 hours 11 minutes ago at 4:04pm |
I’ve heard about the Cummins swap but I don’t know of anyone who has ever done it. I’m sure it’s not cheap either. I’m going to ask around and see if it might be worth it. In that case I would just drive the truck as is until the engine went down and then do the swap.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42022 |
Posted: 6 hours 2 minutes ago at 4:13pm |
https://www.google.com/search?q=Injection+pump+failure+in+pickups+-+type+of+pump+and+resulting+damage&rlz=1C1CHWA_enUS627US627&oq=Injection+pump+failure+in+pickups+-+type+of+pump+and+resulting+damage+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCjU5Mzg1ajBqMTWoAgiwAgE&sourceid=chrome&ie=UTF-8
Diesel pickup injection pumps can fail catastrophically, and the specific failure type and resulting damage vary based on the pump design. The most common types of high-pressure injection pumps in modern diesel pickups are the Bosch CP4, the Bosch VP44, and the Bosch CP3.
< jsuid="TaUOI_b" ="0" -amic="true" -icl-uuid="020cf8fa-f296-45d7-a801-c97f4624368a" aria-label="View related s" ="rBl3me" js="click:&TaUOI_a|S9kKve;mouseenter:&TaUOI_a|sbHm2b;mouseleave:&TaUOI_a|Tx5Rb" -wiz-attrbind="=TaUOI_a_C5gNJc;=TaUOI_a_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIARAB" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24"> Bosch CP4< jsuid="TaUOI_h" ="0" -amic="true" -icl-uuid="3a48a20d-2d0f-4e4d-879b-3b4d42712f41" aria-label="View related s" ="rBl3me" js="click:&TaUOI_g|S9kKve;mouseenter:&TaUOI_g|sbHm2b;mouseleave:&TaUOI_g|Tx5Rb" -wiz-attrbind="=TaUOI_g_C5gNJc;=TaUOI_g_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIAhAA" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24"> This high-pressure common rail pump is used in many Ford, GM, and Ram diesel engines from the 2011 model year onward. < jsuid="TaUOI_k" ="0" -amic="true" -icl-uuid="ac5dbb14-ab08-4b22-900a-7d640aa9db81" aria-label="View related s" ="rBl3me" js="click:&TaUOI_j|S9kKve;mouseenter:&TaUOI_j|sbHm2b;mouseleave:&TaUOI_j|Tx5Rb" -wiz-attrbind="=TaUOI_j_C5gNJc;=TaUOI_j_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIAxAB" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Bosch VP44< jsuid="TaUOI_1d" ="0" -amic="true" -icl-uuid="626c47bc-00d4-42be-a131-e50782f2df30" aria-label="View related s" ="rBl3me" js="click:&TaUOI_1c|S9kKve;mouseenter:&TaUOI_1c|sbHm2b;mouseleave:&TaUOI_1c|Tx5Rb" -wiz-attrbind="=TaUOI_1c_C5gNJc;=TaUOI_1c_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIBRAA" -processed="true" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Bosch CP3< jsuid="TaUOI_37" ="0" -amic="true" -icl-uuid="6d7c5a3c-ba0a-4c53-94a4-a0abd44865bd" aria-label="View related s" ="rBl3me" js="click:&TaUOI_36|S9kKve;mouseenter:&TaUOI_36|sbHm2b;mouseleave:&TaUOI_36|Tx5Rb" -wiz-attrbind="=TaUOI_36_C5gNJc;=TaUOI_36_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQICRAA" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24"> This high-pressure pump is known for its durability and was used on many GM Duramax and some Cummins diesel engines, notably prior to the adoption of the CP4. < jsuid="TaUOI_3a" ="0" -amic="true" -icl-uuid="b41d4bfb-80f2-41dc-b449-c5be95f27777" aria-label="View related s" ="rBl3me" js="click:&TaUOI_39|S9kKve;mouseenter:&TaUOI_39|sbHm2b;mouseleave:&TaUOI_39|Tx5Rb" -wiz-attrbind="=TaUOI_39_C5gNJc;=TaUOI_39_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIChAB" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Common symptoms of any injection pump failure< jsuid="TaUOI_48" ="0" -amic="true" -icl-uuid="6879f1ef-c33d-43e0-9879-968912352b43" aria-label="View related s" ="rBl3me" js="click:&TaUOI_47|S9kKve;mouseenter:&TaUOI_47|sbHm2b;mouseleave:&TaUOI_47|Tx5Rb" -wiz-attrbind="=TaUOI_47_C5gNJc;=TaUOI_47_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIDBAA" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24"> Regardless of the pump type, a failing injection pump typically causes a range of performance issues that serve as early warning signs:< jsuid="TaUOI_4b" ="0" -amic="true" -icl-uuid="499fd311-85c5-4fcb-b0ca-73776135d9a1" aria-label="View related s" ="rBl3me" js="click:&TaUOI_4a|S9kKve;mouseenter:&TaUOI_4a|sbHm2b;mouseleave:&TaUOI_4a|Tx5Rb" -wiz-attrbind="=TaUOI_4a_C5gNJc;=TaUOI_4a_UpSNec;" -ved="2ahUKEwjj19-d48KQAxWOAHkGHbr-BH4Qye0OegQIDRAB" style="margin: 0px 6px 0px 0px; : none 0% 0% / auto repeat scroll padding- border- rgb229, 237, 255; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 28px; : relative; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Coke-in-MN
Posted: 5 hours 57 minutes ago at 4:18pm |
Seems the New and Improved injection pumps have a great failure rate and when they do they contaminate the full system with impending disaster from tank to pump, lines , injectors and finally bank account .
But remember they meet the government environmental outcome of preventing air pollution - dead trucks pose no problems Truck engine or brand of body - SAME PROBLEM WITH PUMPS across all . Even the filter used is of no use once pump starts it's demise of wear . Edited by Coke-in-MN - 5 hours 54 minutes ago at 4:21pm |
PaulB
Posted: 4 hours 45 minutes ago at 5:30pm |
I'm sure the Cummins swap will not cost what the Ford fix will be and you'll still have a PowerJoke.
Just get a Cummins that was before the 98.5 year in a Dodge or a full mechanical industrial or medium duty truck truck engine. Anything that is computer controlled will end up problems in the long run. If you are really serious, I have a 5.9 VE rotary pump engine I'd consider selling.
Ranse
Posted: 4 hours 4 minutes ago at 6:11pm |
I do have the CP4 fuel injector pump on my truck. I’ve been told by countless people that they are junk and ford should be sued over them. It would have been nice to had this information before I bought the truck. I can’t understand why ford super duty’s are so popular. I see them everywhere
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6500 |
Posted: 3 hours 6 minutes ago at 7:09pm |
Ford’s marketing program is one reason for the popularity. And they dodge the lawsuits because the pumps fail after the warranty expires. A lot of people buy the trucks for a status symbol and trade/sell them before they hit 100k miles. Since this is a known defect I feel that Ford should be forced to cover the repair costs.
