Truck bed mat? |
Neal (scMN)
Joined: 11 Sep 2009 Location: Truman, MN Points: 196 |
Topic: Truck bed mat?Posted: 17 Jul 2019 at 9:19pm |
What is the best to put in the bed of a new truck, rubber mat, spray on or carpet?
allis g
Joined: 10 Jan 2012 Location: Templeton Points: 415 |
Posted: 17 Jul 2019 at 9:35pm |
I have had bed liners they rust out the bed and you don’t see it till it’s too late. Used carpet when I was poor got spray on in the latest truck like it the best. Stuff doesn’t slid around
Joined: 11 Sep 2009 Location: illinois Points: 90826 |
Posted: 17 Jul 2019 at 9:37pm |
I have had a rubber mat, about 5/16 inch thick on the floor of my lasts 3 trucks.. Like that the best.. nothing slides and you can pull out and wash out twice a year.
200Tom1
Posted: 17 Jul 2019 at 10:12pm |
Name brand spray on, only way to go as far as I am concerned.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Posted: 18 Jul 2019 at 3:10am |
If I can ever find a rust free bed to replace what my Pickup has, I’ll only go with a spray in liner.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 18 Jul 2019 at 5:38am |
some stuff I know... my '97 F150 has has a liner in the box ALL of it's life, ZERO rust from it being in there. 3 trucks next door,used for /landscaping/snowplowing had sprayin liners, all 3 rust rotted from top front lip down and other spots. All three now have new beds($$$$!!) and liners How a bed holds up depends on what you haul, how often and how you cleanup. Haul sharp gravel and shovelling it out will chew the factory off, so rust will begin. Haul bags of salt that bust...... the bad rust cycle will begin( and never end). I look at sprayon bed liners like powdercoat, unless applied 100% right, over 100% of the box and allowed to 'cure' 100% before install, you've got 100% future problems.ANY knick, gouge, knife cut and water(especially salty water) WILL get in..then the trouble begins. With a liner ,you can (with 2 guys), easily remove and inspect the bed. Aside from 'paint wear', mine's fine. A rotted out box with liner, to me indicates water from the liner got through a hole and sat in the box, because the drain holes in the box were plugged up. In the end what kind of protection you add depends on what you use the box for. What I do know is that any box with a sprayon liner is NOT repairable.
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Posted: 18 Jul 2019 at 6:59am |
As long as the do the correct procedure, I would never be without a spray in job. Factory is el supremo. but i spose it is too late for that now.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12420 |
Posted: 18 Jul 2019 at 8:52am |
Well there you have it! The best is a spray on. Except for liners. Except for rubber mats.
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 18 Jul 2019 at 10:47am |
For what it's worth I have had a rubber bed mat in my 94 since new.
1957 WD45 dad's first AC
Robert Musgrave
Silver Level Access
Joined: 11 Sep 2009 Location: SE Wisconsin Points: 246 |
Posted: 18 Jul 2019 at 12:03pm |
½" Plywood with a 2x4 at the front (toward the cab) and hinged at the tailgate. With the tailgate down, makes a flat surface almost to the end. Finished with two coats of machinery grey enamel. Made for a 2007 Canyon, it is now in a 2015 Canyon. Great for hauling and sliding firewood. Gets a little slippery when wet, and can be removed to clean.
R. Musgrave
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 18 Jul 2019 at 4:46pm |
I had Line-X sprayed in mine when new, then put a rubber mat on top of it. The Line-X is a little slippery and does not stop the bed from getting dented when, say, a heavy engine block tips off the pallet....ask me how I know
plummerscarin
Posted: 18 Jul 2019 at 5:59pm |
I have an 89 Chevy with a plastic bed liner since new. It is the only area where this truck has NO rust. My 05 Chevy, same thing. The 89 has 250,000 on it and got used hard. Also the plastic liner is ideal for using that Loadhandler as seen on TV.
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 19 Jul 2019 at 1:06pm |
My 89 Jeep Comanche has had a plastic bed liner since new and I have not noticed that the bed shows any sign of rust when i have been under the truck. It is slippery and I usually tie down anything that might slide around.
shameless dude
Posted: 19 Jul 2019 at 1:38pm |
put a topper on it
Ken(MI)
Joined: 14 Sep 2009 Location: Lansing, MI Points: 619 |
Posted: 19 Jul 2019 at 8:50pm |
Rubber floor and plywood over it works for me, but we load with forklifts all the time and rubber alone doesn't like that.
Tbone95
Posted: 20 Jul 2019 at 6:20am |
I hate toppers. If I wanted a suburban, that's what I'd buy!
jaybmiller
Posted: 20 Jul 2019 at 6:26am |
got a perfect 'topper' from an '04 SB Chevy, can't GIVE it away. even has privacy glass all round, goin to cost ME money to take to dump...arrgh....
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 20 Jul 2019 at 7:48am |
Yea and as soon as ya do that some one wants it.
shameless dude
Posted: 20 Jul 2019 at 1:02pm |
no matter what you put in your truck box, make sure you have drain holes.
