Trouble with my D-17 Diesel |
Page 12> |
Stephen069 ![]() Bronze Level ![]() ![]() Joined: 22 Nov 2019 Location: Kansas Points: 13 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Nov 2019 at 12:15pm |
![]() Edited by Stephen069 - 23 Nov 2019 at 7:19am |
Rhoadesy_65 ![]() Bronze Level ![]() ![]() Joined: 28 Jul 2019 Location: Versailles, OH Points: 164 |
Make sure you type out your issue in your post, not on the title of your topic.
Farmin' with 1981 7010 PD, 1983 6080, 1983 8010, Gleaner R42 in Darke County OH
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12236 |
He did! You know, it acts like TH!
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8655 |
The engine is locked....the tire is flat....transmission is stuck in gear.....WHAT!!!!
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Total Hell
MattLF9 ![]() Bronze Level ![]() Joined: 27 Nov 2009 Location: Minnesota Points: 187 |
This whole topic and replies.....ROFLMFAO!
A little CQB never hurt anybody.
Do reply again, we are just poking you as we call it. The guys really do like to help you solve your problems with your Tractor.
BEK ![]() Silver Level ![]() Joined: 05 Nov 2017 Location: Wilmington, NC Points: 216 |
Does this happen only when you round bale the Hemp?
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8535 |
Stephen069, Welcome to the forum! Some of us have used these forums a lot and are pretty comfortable. Many folks here can help you with orange tractor issues too! My guess is your a 1969 model?:) Regards, Chris
MDWilliams338 ![]() Silver Level ![]() ![]() Joined: 19 Nov 2018 Location: NC Points: 476 |
Got me curious for sure.Drove it where ? And parked? Was the 17 a chariot for a hot date and then died?🤔
It isn’t how you die.It’s what you live for.-Daniel Boone |
I don't feel too bad about giving him grief with a post like that.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6081 |
He parked it In the Castle of Aughhh.... https://www.youtube.com/watch?v=ZlIz0q8aWpA ![]() ![]() ![]() |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5903 |
The New Member Stephen was last on here an hour ago. I hope he ignores all the B/S posts and comes back. Stephen You can 'Edit' your first Post by clicking on 'Options' in upper R/H corner. Change the 'Subject' to 'Trouble with my D-17 Diesel'. Then in the Body of the Post describe the problem you are having. and 'Welcome to the Forum' Gary |
wekracer ![]() Orange Level ![]() ![]() Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
He updated his post. Go back to the top to his first post.
If it sits for a while does it start up normally. |
I'm not a diesel guy, but on a gas one sometimes the starter Bendix gear and flywheel get locked up together and nothing will move. If this is the case you pull the starter and check both gears for any problems, if none reassemble. More guys will be on with more ideas for you soon.
And Welcome To The Family
![]() Edited by chaskaduo - 23 Nov 2019 at 8:01am |
lowell66dart ![]() Orange Level ![]() Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
The diesel D-17 starter is easy to take off, three bolts. Get it off and hook some jumper cables to it to test it to eliminate the starter. While it's off take a prybar and try and move the engine with the flywheel. That should narrow it down a little.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Could have violent in a cylinder. MACK
Ok Mack tell me what a violent is I guess I’m getting old because I’m lost
I swear MACK voice texts some of these....got me guessing too....can't come up with a word that sounds similar to explain "violent"
Just curios when you say it seems locked but assert it's not starter or electrical. How do yo know that? Like others said,I'd pull starter and pry on ring gear to prove it's the engine. Edited by SteveM C/IL - 23 Nov 2019 at 11:21am |
NomoreJohnDeere ![]() Silver Level ![]() ![]() Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
Leave the pto on?
water in cylinder? starter ring gear jammed? clutch hung up? |
HD3
Is Mack trying to say vapor lock in a cylinder?
Boy does this old man feel like a mule Thanks you guys It was a Rock between the bendix and the ring gear Slap myself for this one
Hey we all go through it sooner or later.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24736 |
Two good things about it... 1) you FOUND the cause... 2) it was EASY to fix... Jay |
Remember, it's always something simple. It's finding out what the problem is that gets complicated.
No doubt it’s simple and I am so glad. Needed to move some big bales and my little Ford won’t do the job lol
...and who woulda thought a rock could even end up there?....it's not automatic to say "Did you check the ring gear for a rock?"
Glad it worked out for you. There could be a long thread on mishaps and I can attest I’ve had many.One of my best was setting 2 acres of hay on fire about 10 yrs ago from a stuck bottom roller that got grease hot and set the guts of my baler and field on fire before we could get it put out.....and I had a whole highway of spectators 😂
Edited by MDWilliams338 - 23 Nov 2019 at 4:02pm |
I don’t have a clue how a rock could end up where it did lol
Page 12> |
