transport valve on WD45
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Topic: transport valve on WD45
    Posted: 23 Jun 2011 at 8:35pm
Found a unit.  Need help on a rebuild.  Got the unit apart.  Looks to be all there.  Are there any O-rings in the unit?  I assume there needs to be something on the threaded shaft to keep oil from seeping out.  Also there is a small(.060) hole in the large dia end of the unit that appears blind, is this true or do I need to soak it longer?
