transmission lock up |
michale34
Topic: transmission lock upPosted: 17 Dec 2012 at 2:07pm |
I got my dad 6g hung in geer a few times and we would pull the shifter and pour a little oil in it and reline the forks usualy it got hung in high forword geer.
Randaleky
Joined: 17 Aug 2011 Location: belfry, ky. Points: 427 |
Posted: 16 Dec 2012 at 1:03pm |
always nice when someone post that problem corrected and a thanks !
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 16 Dec 2012 at 12:59pm |
I'm shifting again. Thank you to gemdozer and Coke-in MN
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42271 |
Posted: 15 Dec 2012 at 8:55pm |
side bolts into shifting tower . remove full lever and the shift fork ball .
using a long screwdriver or a jack handle tire iron = move all 3 forks into neutral position .
gemdozer
Posted: 15 Dec 2012 at 1:28pm |
You could removed the 2 bolts from housing shift lever and pull out the lever gear shift and check inside with a light if the end shafts notches are in line and if not ,use a long screw driver inline the 3 notches and reintaled your shifter and try to shift and the master cluch must be in neutral fonction
Dozer
Posted: 15 Dec 2012 at 12:10pm |
I was going for just one more bucketload with my HD6G when my transmission locked in high speed reverse. It is solidly in gear not caught partly in 2 gears. The transmission locking plunger is moving correctly. I removed the locking plunger sleeve and boot and moved the locking plunger several inches but I could not remove it.
I wiggled the shift lever but it didn't come out of gear. It is not in a good location for me working on it. Sugestions please. |
