trans seal.. |
bmartin55
Topic: trans seal..Posted: 21 Apr 2015 at 5:33pm |
I have a seal leaking ..when I put in oil in trans it goes into my power directory. .how hard is this to fix ..and parts number I need.
Dr allis can u help.. Thanks.bob |
bmartin55
Posted: 21 Apr 2015 at 5:34pm |
Sorry it is a d17 puller..
thanks.bob |
Posted: 21 Apr 2015 at 9:33pm |
Did you remove the PTO shaft?????
bmartin55
Posted: 21 Apr 2015 at 10:20pm |
Yes pto is removed..all lighten up..
Posted: 21 Apr 2015 at 10:29pm |
Well, you have to shove something back into the front PTO shaft hole, the oil just runs thru the seals when the shaft is removed. A great big cork or plug or a short chunk of shafting the same diameter as the PTO shaft you removed.
bmartin55
Posted: 21 Apr 2015 at 10:35pm |
Ok I can do that .
The guy I got it from did it.. I can fix.. Thanks Dr allis.. Bob |
mattb
Posted: 22 Apr 2015 at 8:19am |
i just let mine flow back and forth may have to add a couple times and recheck both compartments only use mine to pull with.
bmartin55
Posted: 22 Apr 2015 at 9:03pm |
That's all I do.is pull ..
MACK
Posted: 24 Apr 2015 at 9:41pm |
If you keep the level at trans. level you are loosing hp because pd is running in oil. MACK
Posted: 25 Apr 2015 at 6:45am |
That's right. The Power Director oil level can be and is lower than the transmission oil level. If anything you can run the trans an inch or so overfull to protect the differential. The PD clutch overfull just wastes HP.
