Tractor w/no compression after sitting many years
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Tractor w/no compression after sitting many years
    Posted: 22 Sep 2018 at 11:01am
Any advice guys on what to do... it is a Farmall F20. Do I put a couple pumps of engine oil in the spark plug holes?
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 11:13am
Shoot about 6-8 shots of auto trans fluid in each spark plug hole. Valves may be stuck. Remove valve cover and spray valve stems through the valve spring coils with PB Blaster or your favorite penetrating oil to get valves moving. Leave plugs out and turn engine over by hand and watch that all valves move full travel. Spray with more PB Blaster and repeat.
Once you get it running set valve clearances at .014" Hot.
