tractor tire size
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: tractor tire size
    Posted: 14 Apr 2018 at 12:56pm
What size tires in the old school sizes compare to metric sized tires 600/65R34? Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 11:04pm
is it 600x17's in radial?
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2018 at 12:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2018 at 7:30am
No, it's 34 inch rear tractor tire, just in the metric size. Darrel
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2018 at 7:32am
That would be about a 24x34 flotation tire. You'll need new rims to put on inplace of your 18.4x34 tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2018 at 7:38am
Thanks for the chart, Lee. I see that size is compared to an 18.4 34, but listed under the "large" series. If I get these tires, they would be replacing 18.4 34's on my one ninety gasser. But on the chart, there is an asterick, which indicates needing a rim change, I would guess it to mean that it requires a wider rim. Doesn't really say how much wider, though. I suppose that if I got the tires, it sometimes says on them how wide of a rim would be required. Then comes the question; do I try to find a set of new or used rims that are wider, or split the old ones with my plasma cutter and weld bands into them. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2018 at 8:12am
what's wrong with buying tires that already fit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2018 at 1:02pm
Takes the fun out of it. Actually I have an optimistic hope that maybe I can snag these for a descent price, and they are an awesome tire. My XT could use a beefier set of meats on the back, so if I get these 600/65R34's, they'll probably go onto the XT, and the 18.4 X 38's presently on the XT will go onto the gasser. This is beginning to sound like a project for Eldon........Eldon....? ELDON.......? Are you there buddy, I need your help! Darrel
This page was generated in 0.395 seconds.
