Tractor Pulling Madness |
Page <12 |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 31 Oct 2011 at 9:52am |
Ah... the other question... tire ballast.
There's advantages and disadvantages to ballasting techniques. When doing tractor-pulling, you'll see that most guys don't run substantial amounts of liquid ballast, and there's several reasons why. Here's a short list of the advantages and disadvantages, and that'll sum up why they employ ballast the way they do: Liquid ballast advantages: Cost Mass (it can get heavy fast) Position: tire fluid CAN present the lowest center-of-gravity of any ballast technique... but only if the tire is partially filled. The maximum CG of a ballasted tire will NEVER be higher than the center of the wheel, as such, a half-filled tire will lower the tractor's composite CG. Inertia- the tire can spin without the fluid 'following along', so the wheel can start or stop motion and not cause an appreciable strain on the drivetrain. Load: Tire fluid is in the tires, so it's not carried on the chassis, not loading bearings or axle housings. Disadvantages: Position: your ballast is ALWAYS centered on the centerline of the axle. If you need more weight FORWARD of the axle, tire ballast will NOT help. Predictability: Adding or removing 34lbs of tire ballast to suit a competition scale is not fun... you'll be standing out there, helping the tire pee into a graduated cylinder, and weighing buckets of fluid to sort it out. Really fun trying to get two ballasted tires to weigh the same amount. Track adaptability: Tire changes suck... and carrying several sets of tires to accomodate a varying track makes your trailer really heavy, really fast. Tire flexibility: Gases are compressible, liquids are not. When you use a tire filled with air, the amount of deflection the tire will produce under a given force, is a function of the initial pressure (sitting on a jackstand) to the final pressure (sitting on the ground). Since air compresses, the tire deflects fine, and pressure inside the tire will rise just a smidgen. If you replace HALF that air with fluid, you're effectively removing half the compressible volume, so the pressure CHANGE between jackstand and ground DOUBLES. Now remove all but just a tiny bit of air, replace it with fluid... the pressure change will be dramatically higher. This is why, when driving a tractor with fully-filled tires... the ride is rough... no compliance to the earth. Iron/steel/lead weights: Advantages: Predictability: a 68.3lb iron weight, will generally always be 68.3lbs, unless you drop and chip a chunk out... and paint is a pretty good indicator of damage. Nice thing, is that a 68.3lb iron weight can easily be measured out on your wife's digital electronic bathroom scale, and while the scale may NOT be perfect, it'll be a whole lot closer than say... a 3-gallon bucket of liquid, where part of it spilled on the ground... and of course, you won't be stealing your wife's bathroom scale to weigh buckets at the track... Placeability: You can put it behind the wheels, under the wheels, in front of the wheels, above the wheels... alongside the clutch, out on a bracket up front, all on the left side... wherever you want, in segments you want. {important note here- if you use iron wheel weights, it will increase the polar moment of inertia of the drive wheels, which can be dangerous in competitions where high wheel speed is allowed... a wheel that breaks loose, and has a high polar moment, will want to continue to spin, and roll through all sorts of stuff before stopping). Iron weights, especially easily removable ones, can be moved from tractor to tractor, so that if you have two machines, and pull in five classes, you can do it all with just one set of weights- by moving weights from tractor to tractor. Start with the tractor extra-light (aluminum wheels, etc) in the smallest, and add weights as you move up in classes. Disadvantages: Cost to obtain. Yeah, they're pricey compared to liquid, but then again, you won't spill too much iron on the ground, and not be able to FIND it... Cost to use: Iron weights and old men aren't a great combination. When using iron weights, one either needs to have a good medical card, or bring along a pair of high-school linemen as a pit crew, and they eat lots of expensive pizza. Cost of gloves and shoes: When having iron weights lying around in the shop, they frequently tip over onto your fingers and toes. Best to budget for thick gloves, band-aids, and steel-toe'd boots. Did I mention a good medical card? Edited by DaveKamp - 31 Oct 2011 at 9:55am |
Ken in Texas
Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Posted: 31 Oct 2011 at 10:14am |
The Smaller Tires on the other CA were so far gone that the brand and size was not easy to read. They were 10-24s with 45 degree lugs. Some were missing . Some were pealed back and packed full of dirt underneath . We both pulled in first so the gear ratio was different due to tire circumfrence. Neither engine was anything but bone stock and both of us spun out with power to spare . My drawbar set up and his could have made a huge difference. His was home made and shorter than my stock length Pin hitch length . Both were at the max height of 20 inches. His weights were on the floor pan and hanging half ahead and under the axle , No wheel weights and water in 1tire. No extra forward weight other than all the cultivator brackets left on the tractor.
I had wheel weights. No water. And all my other weights were directly behind and above the center line of the axles. I was a little light in the front. Real light at spin out.
I did not notice where he picked up the front and by how much or if he picked up the front at all.
My CA without any weights and water with me on it weighs a certified 2440. With 2-145 lb wheel weights plus other loose weight I get up to 3000. His CA was close to 3000 without the 5 yellow suitcases he hung under and laid flat under the seat. Both CAs have the heavy Cast SFW.
The track changed a lot over night and went from damp and a bit soft to hard and dusty. The finishing order did not change.
The sled chooses the line you are forced to take for you in the lighter classes. I always try to keep myself pulling directly ahead of the center of the sled and hope to miss any holes. The track master at the drivers meeting reminds the light weight pullers of this fact and cautions them to not even try to change the direction of the sled.
Here is my theory on a big tire contact patch verses a small tire patch. With the same downforces applied the smaller tire has more lbs per square inch than a big tire. It's like driving a blunt end 16 penny nail verses a 12 inch bolt with the same hammer. If the Pounds of downforce per square inch IN TOTAL for the big tire calculates to be less than the small tire the small tire has the slip advantage and will go farther. Does this make any sense???
If the hard track is under loose dirt the narrow tire will find quicker than a big wide tire . The big tire will probably spin out in the marbles without getting down to a solid pulling surface.
Panky asked about what the holes in the track left behind looked like. Thats something I didn't take much notice of. They ask us to not dig holes after the forward progress stops at the drivers meeting. I would imagin the little tire dug a deeper hole than a big tire. Probably found some virgin soil.
This is the second time in a long time that I went pullin without water in the tires.
My drawbar is fixed. I think I need a more flexable design where changes in height and length are quick and easy. I also need weight brackets fabricated ahead of and behind the axle. To adjust balance better. I won't need as many weights if I water up the tires to help get to 3000. I figure I need about 16 gallons in each tire. Lets see, bare tractor and me 2440 + 290 wheel weights + 270 water = exactly 3000. Our rules allow for a 1% over in class so to be on the safe side about 15 gallons of water in each tire will be OK. May go nuts and go to 4000 and play David against the Goliaths just for fun. Is that madness or what?
Ken in Texas
Posted: 31 Oct 2011 at 10:41am |
Good stuff Mr Dave Kamp.
You got the physics of Tractor pulling success figured to the ounce. I just love not having to ponder the why and wherefore when sombody has already figured it out and is will ing to pass it on. Thanks for jumping in here and giving us all a education.
OT- By any chance do you have any Holland Dutch folks in your background?
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 31 Oct 2011 at 10:43am |
Charlie 175. When you move to the drawbar you are actually hooking higher. Your drawbar is running down hill from the final drives. Your ASAE hitch runs the hook point lower to the ground than when hitching to the drawbar. If you look at my drawbar picture I have the clevis under the drawbar. If I put it on top the front wheels come up on a short chain.
I have a stack of 1/2" steel blocks on the bolt and a 1/2" difference one way or the other makes a difference. Carry a ruler and a note pad and make small changes they make a note of what you did as well as the results.
DSpears N IL
Silver Level Access
Joined: 11 Sep 2009 Location: Rockford,Ill Points: 418 |
Posted: 31 Oct 2011 at 12:02pm |
Hi Ken! I will add a couple pictures from pulling with worn Goodyear 13.6 to like new Firestones at 7 to 8 lbs PSI. I like my newer Stones that was on the rims that you now have. DeWayne
j.w.freck
Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
Posted: 31 Oct 2011 at 12:07pm |
dave... i have another question for you,in a 13.9x28 rear tire how many gallons of cheap gl;ycol will i have to add for down here in texas where the temp.very rasrly gets below 10 degrees .according to my handy dandy chart,each tire holds 43 gallons of water with a weight of 360 lbs.i figure 4-5 gallons of glycol will be ok...
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 31 Oct 2011 at 12:14pm |
boone county?
j.w.freck
Posted: 31 Oct 2011 at 12:20pm |
thx ed
DSpears N IL
Silver Level Access
Posted: 31 Oct 2011 at 12:31pm |
YES to Boone County!!!!!
DeWayne
j.w.freck
Posted: 31 Oct 2011 at 12:37pm |
sounds like i am dealing with a bunch of wineos.......
Ken in Texas
Posted: 31 Oct 2011 at 1:14pm |
Not that hard to figure out JW. There are sometimes two separate Q&As going on the same time. I only have 2 gallons of green stuff in the 13-6s on my work tractor. I don't even think it gets slushy. If it did, whats the hurt? It has been in there for a long long time. The pullers stay inside and it seldom gets anywhere below freezing in the barn if I remember to close the doors. They got just plain water in them. Plain water weighs like 8.3 lbs to the gallon.
If I know how much weight I want to add I measure the water before I put it in . A tank sprayer puts it in without spilling a drop. Now If I can just figure out exactly how to get it all back out. I'm working on that with a siphon tube than fits in the stem with the valve core out.
DeWayne. The Good- Years I have aren't quite as worn as yours. What Ply Rateing are those? What weight class are you pullin in in the pictures. Welcome to the Madness. Kenny
BTW. The JD rims have the 19 3/4 c to c bolt circle so they fit all my wheels perfect. The first Jap rims with Firestones on em I found were off a MF 1050 and were 20 1/4 C to C
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 31 Oct 2011 at 5:28pm |
the reason i asked about your holes is they tell you alot about tire pressure ,flat hole in bottom is right ,cuped hole to much air, hole raised in the center not enough air.
Ken in Texas
Posted: 31 Oct 2011 at 6:58pm |
I can see now that I need a pulling crew to help me do all the checking of this and that carefully before the track maintainer covers up all the evidence.
DeWayne
Do you have a picture of your drawbar setup we can look at? I like that weight box design and location full of what looks like a couple more engine sideweights and other stuff. I'm thinking a few more pounds up front will help me a bunch if it works for you. All I have up there now is the cast iron SFW. Are you running with any water in the tires?
mlpankey
Posted: 31 Oct 2011 at 7:09pm |
when you back up to let the chain be unhooked and start to pull off look back just a few seconds.
DSpears N IL
Silver Level Access
Posted: 31 Oct 2011 at 8:18pm |
Hi Ken! I do not have any ballast in the tires. The tires are 4 ply. The 7 to 8 lbs of tire pressure gives me the flat bottom track when I am done pulling. My Drawbar is the standard snap-coupler with the twisted clevis as hig as it will go. I had the weight bracket fabricated to hold 2 sets of engine sideweights or hang suitcase weights on. I have 2 sets of rear wheel weights along with front wheel weights. I had another weight bar fabricated to mount on the front cultivator bracket. The lightest class we pull in is 3600lbs which is the class with the goodyear tires. The 2nd photo is from this year with the Stones tires and 4000 LB class. Hope that I have answered all open questions. DeWayne
j.w.freck
Posted: 31 Oct 2011 at 8:35pm |
ken...i pulled 132.4 with the 45-diesel.john deere a pulled 132.5.didnt have enough md 20 20 in the tires...do they have any more pulls in our area soon???
Ken in Texas
Posted: 31 Oct 2011 at 10:46pm |
That's about it for this year JW.
There are a few antique pulls in the early spring out west of us. They are put on by local clubs using the pay per hook system that is so popular out that way. One privately owned sled makes the rounds out thata way. I figure if I got to haul that far to pull for bragin rites only I shouldn't have to antie up to hook on top of my other expenses.
Our EastTX club sled only gets used twice a year. April and October. Lonestar Tyler has a sled that gets used once a year in September . The Lake country sled may be used up to four times a year up around Sulphur Springs and Winnsboro. I think Red Rivers sled is used once at Paris. The North Texas club sled has a once a year pull at Terrel. Northern Lousiana has pulling events as does Southwest Arkansas. As far as I know our EDGETA insurance is good for any of the Ark-La-Tx pulls. All the pulls close don't ask for a hook fee. There is a rumor that there may be a pull one day at the Canton Show and Swap Meet. It never seems to materialize. I guess the next one real close by is Henderson in April 2012.
Thanks for the great pictures and details Dewayne. The last time I checked my tire pressure, it was 5. Maybe less now that it cooled off. Seriously thinking about adding a little water and loosing some iron before I drop a side weight on my foot.
DaveKamp
Posted: 01 Nov 2011 at 1:01am |
Hi JW!
Okay, assuming 43 gallons TOTAL... Freezing point for a 75%/25% mix of water and PROPYLENE GLYCOL (non-toxic pink RV anti-freeze) is 12.5F. Propylene Glycol weighs 8.625 lbs/gallon. With that, you'll have 32.25gallons of water (258lbs) and 10.75 gallons (92.7lbs) for about 350lbs. Interesting facts to note- Etheylne Glycol weighs just under 9.5lbs per gallon... heavier than water. If you fill your radiator or tires with pure Ethylene Glycol, you'll experience freezing at -10F... Yep, anti-freeze will freeze... But if you add water to create a 70% EG/30% water mix, the freezing point DROPS to -60F!!! To reach your 10F, you gotta go about 35% EG to 65% water... that comes out to 28 gallons of water, 13 gallons of Ethylene Glycol, for a total load weight of 224+123.5= 347.5lbs. Yes, the math is right... you'll actually have a few more pounds, by using the lighter non-toxic stuff... |
j.w.freck
Posted: 01 Nov 2011 at 6:28pm |
well ken.....i got me another 45-diesel today...pick it up when we go deer hunting at the farms...
Ken in Texas
Posted: 01 Nov 2011 at 7:07pm |
If you keep finding them up in cold country and bring them all down here, the price for the last few left up there is going to be out of site. They are already talking about how rare they are. Except at your house.
j.w.freck
Posted: 01 Nov 2011 at 9:16pm |
dave...thx for the glycol/water ratio.very close to what i had figured out...thx again
monitordoc
Joined: 15 Feb 2010 Location: Minnesota Points: 187 |
Posted: 01 Nov 2011 at 9:41pm |
What method of paying for the sled do you have? Here in minnesota I have only seen pay per hook. Usually $15 per hook.
WD,D17-S4,180,D21
Ken in Texas
Posted: 01 Nov 2011 at 11:03pm |
Paying for the Sled and Scales? I hope this answers the question. It is paid for and has been for years. The East Texas Antique Tractor and Engine Association Owns it. It was built and maintained by association members. Club Members, as a team, volunteer their labor to operate and maintain the equipment. Pull back tractors are usually donated by local dealers. A few Sponsors buy advertizing displayed on the sled and on banners at events.
Our Club Members bring our Sled to the State Fair of Lousiana at Shreveport and area EDGETA pullers from 4 states put on a Friday and Saturday Antique Tractor Pulling Contest & Show at the Fair. When we are not pullin we are workin so the others can pull. We are in our tenth year now of putting on this show. The Fair in return provides a space for a track and makes a sizeable financial contribution to the clubs general fund for our efforts. The Fair provides the awards for the 1st, 2nd, and 3rd place winners in each class. The sled was built by the membership and maintained by the membership . Funding for Updates and general maintainance of the Sled, Scale and related items is paid for out of the clubs general fund.
The club also puts on a local 2 day show and pull at the Rusk County Ag Center in the spring. The public is charged Admission to the show. Exhibitors and pullers get in free by showing their current EDGETA Membership / insurance card. At this event again it works like this. When your not pullin and there is work to do or a job needs doing you volunteer.
We find no need to charge a actual per hook fee nor do any of the other regional clubs maintaining a sled and scales and putting on a show. The regional Clubs are all Branch Member Clubs of EDGETA and pull under EDGETA Antique Tractor Pull Rules.
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 02 Nov 2011 at 6:29am |
Here most, if not all antique pulls are pay by the hook with spectators getting in free.
Charlie
trkpuller
Posted: 05 Jun 2022 at 7:02pm |
So how fast can you spin a ballasted tire? I see some hot farm tractors with incredible wheel speed.
Posted: 05 Jun 2022 at 7:11pm |
No one who makes serious HP has fluid in the rear tires. Why not?? Most tractors have been stripped of any excess weight to get into specific weight classes. Fluid just isn't used.
Page <12 |
